New Reply
Force of neodymium magnet inside a electromagnetic coil
Share Thread
Jul8-11, 04:09 AM   #1
Hey guys,
Im trying to design a electric gear shiftier for a motor bike. Basically I require about 200N of force to change gear with a 10mm throw (in both directions). I would like to use a tube neodymium magnet. (23mm diameter 25mm high with a 5mm hole throw the centre with a N48 grade)
What I need help with is calculating the number of turns of wire, the current and gauge of wire of the coil. I will be using 12V supply and Im limited to 60amps current draw.
So the magnet will be placed in the middle of the 45mm long coil and the direction of current flow will be changed to make the magnet travel in one direction or the other to change up and down. The magnet will return to the centre of the coil via a recoil spring.
Any help will be greatly appropriated.
Thanks so much guys
Alastair
PhysOrg.com physics news on PhysOrg.com
>> Kenneth Wilson, Nobel winner for physics, dies
>> Two collider research teams find evidence of new particle Zc(3900)
>> Scientists make first direct images of topological insulator's edge currents
Jul8-11, 09:04 AM   #2
If you don't get an answer you might want to try posting in the Engineering sections of Physics Forums.
New Reply
Similar discussions for: Force of neodymium magnet inside a electromagnetic coil
Thread Forum Replies
Neodymium Magnet Polarization General Physics 11
Force on a Permanent Magnet Falling through a Coil Classical Physics 3
powdered neodymium magnet General Physics 3
What force acts against a magnet passing through a coil? Classical Physics 10
Induction of a coil and force exerted on magnet in a magnetic field Classical Physics 1
