Optimizing MCAT Physics: Understanding Oscillation with Two Springs
  • Thread starter Thread starter jehan4141
    Physics
The discussion revolves around the oscillation of two springs with equal masses but different spring constants, focusing on their maximum velocity, displacement, total energy, frequency, and period. Participants are exploring the relationships between these variables in the context of oscillatory motion.
  • Participants are examining the implications of different spring constants on oscillatory behavior, questioning the definitions of displacement and amplitude, and discussing the relationships between frequency, velocity, and spring constants.
Some participants have expressed uncertainty regarding the distinction between displacement and amplitude, while others have proposed that a larger spring constant could lead to a higher maximum velocity. There is an ongoing exploration of how these concepts interrelate, with no explicit consensus reached.
Participants are navigating the definitions of terms used in the problem statement and the implications of the equations related to oscillation, while also considering the constraints of the problem as presented.
jehan4141
Two springs with equal masses attached but with different spring constants (k) oscillate with the same amplitude. The spring with the larger spring constant (k) has:
a. a higher maximum velocity
b. a larger maximum displacement
c. a lower total energy
d. a lower frequency of oscillation
e. a longer period of oscillationI'm pretty certain that it is not C, D, E based on the equations for both period and frequency and the formula for Potential Energy = 1/2 kx^2
I think it is between A and B. Please help :) thank you!
Welcome to the PF.
Is there a difference between "displacement" and "amplitude"?
What's another name for maximum displacement? Does the term appear in the question statement?
I am unsure if there is a difference.. :( There is no further clarification.
I have a feeling that it could be A based on the fact that, the larger the spring constant (k), the larger the frequency --> f = (1/2pi)(sqrt k/m)If you plug in a large frequency into the equation velocity = frequency x wavelength, you get a higher velocity. However, the thing is, you can only change the velocity of a wave by changing the medium that the wave propagates through. Since we are using 2 different springs, with 2 different spring constants, does this mean we have different mediums? Because that would make A the answer I believe.
THANK YOU FOR THE WARM WELCOME...this message board is awesome!
oh and, I know that amplitude has NO EFFECT on period if that helps?
