Integral(s) involving differential equations or contour integration
The discussion revolves around the evaluation of the definite integral \(\int_{0}^{\infty}\frac{\cos{x}}{x^2+1}dx\) using contour integration and other methods. Participants explore the challenges faced in applying contour integration techniques and the conditions for differentiation under the integral sign.
  • One participant describes their approach using contour integration and the residue theorem, noting the poles at \(i\) and \(-i\) and attempting to evaluate the integral over a semicircular contour.
  • Another participant points out a mistake in the original approach, specifically regarding the behavior of \(\cos(re^{ix})\) and its implications for the limit of the integral as \(r\) approaches infinity.
  • There is a suggestion to consider the integral of \(e^{iz}\) instead, which may lead to a valid evaluation of the original integral by taking the real part of the result.
  • Participants express uncertainty about the conditions for differentiation under the integral sign and seek alternative methods such as series expansion.
Participants do not reach a consensus on the correct approach to evaluate the integral, and multiple competing views and methods are presented. The discussion remains unresolved regarding the best technique to apply.
Participants note limitations in their approaches, including the violation of conditions for differentiation under the integral sign and the behavior of complex functions in contour integration.
This discussion may be of interest to those studying complex analysis, contour integration techniques, or anyone looking to evaluate integrals involving oscillatory functions.
Hello, all:
I have a few questions concerning a definite integral where I am meeting with limited success. The most important problem concerns:
[tex]\int_{0}^{\infty}\frac{\cos{x}}{x^2+1}dx[/tex]
Contour integration always has been my last resort, but differentiating under the integral sign, I soon found that some of the conditions were violated and simply could not find the right parameterization so that they held.
Relevant equations:
Naturally the residue theorem in complex analysis. I don't really have anything else...
The attempt at a (wrong) solution:
I attack the doubly improper integral over the entire real line (this will give me twice the integral because the integrand is an even function).
I note that there are no branch cuts and that poles exist at i and -i, so I construct the usual semicircular contour and evaluate the integral:
[tex]\oint_{C}\frac{\cos{z}}{z^2+1}dz=\int_{-r}^{r}\frac{\cos{x}}{x^2+1}dx+\int_{0}^{\pi}\frac{\cos{re^{ix}}}{{r^2}e^{2ix}+1}ire^{ix}dx[/tex]
In both cases I take the limit as r goes to infinity. In big-O notation:
[tex]\frac{\cos{re^{ix}}}{{r^2}e^{2ix}+1}ire^{ix}\in \frac{O(r)}{O(r^2)}[/tex]
Which goes to zero as r goes to infinity, so the second integral goes to zero.
Therefore:
[tex]\oint_{C}\frac{\cos{z}}{z^2+1}dz=\int_{-\infty}^{\infty}\frac{\cos{x}}{x^2+1}dx[/tex]
[tex]\frac{1}{2}\oint_{C}\frac{\cos{z}}{z^2+1}dz=\int_{0}^{\infty}\frac{\cos{x}}{x^2+1}dx[/tex]
Then I calculate the complex residue of i (the only pole enclosed in the contour). Since this is a simple pole of a ratio of two functions f(z)=cos(z) and g(z)=(z^2+1), the residue at i is:
[tex]\frac{f(i)}{g'(i)}=\frac{\cos{i}}{2i}=\frac{\cosh{1}}{2i}=\frac{e+e^{-1}}{4i}[/tex]
The residue theorem tells me that [itex]2i\pi[/itex] times the sum of the residues gives me the value of the closed contour integral, so I have:
[tex]\oint_{C}\frac{\cos{z}}{z^2+1}dz=2i\pi\frac{e+e^{-1}}{4i}=\frac{\pi}{2}(e+e^{-1})[/tex]
By the transitive property, this shows that:
[tex]\int_{0}^{\infty}\frac{\cos{x}}{x^2+1}dx=\frac{\pi}{4}(e+e^{-1})[/tex]
When I did the contour integration I must have done something wrong because http://www.wolframalpha.com/input/?i=integrate+cos[x]/[x^2+1]+from+0+to+infinity" gave me this:
[tex]\int_{0}^{\infty}\frac{\cos{x}}{x^2+1}=\frac{\pi}{2e}[/tex]
My question is this: what did I do wrong? Also, is there a clever t-parameterization I can use which doesn't violate the conditions of differentiation under the integral sign? If there is a method to subdue this integral outside of contour integration, I would be pleased to know: a series expansion, differentiation under the integral sign (I presume this would require a differential equation solution, as e appears in the result)...
All help is appreciated, as always.
QM
{?} said:
Hello, all:
Relevant equations:
Therefore:
[tex]\oint_{C}\frac{\cos{z}}{z^2+1}dz=\int_{-infty}^{\infty}\frac{\cos{x}}{x^2+1}dx[/tex]
[tex]\int_{-infty}^{\infty}\frac{\cos{x}}{x^2+1}dx=\frac{\pi}{4}(e+e^{-1})[/tex]
QM
Fixed LaTeX. You have to use / in the [ /tex] brackets, not \.
Thanks, micromass. I'm completely new to this LaTeX equation thing...I've been on Math Equation Object for so long now...
{?} said:
In big-O notation:
This is where your mistake lies. You have [itex]\cos(re^{ix})[/itex], but this is the complex cosine and it can grow exponentially large! I.e. you don't have [itex]|\cos(re^{ix})|\leq 1[/itex] anymore.
In general, this method won't work because the second integral does not go to 0.
What to do then? Well, it turns out that we can consider (with C being the semicircular contour):
[tex]\int_{C}{\frac{e^{iz}dz}{z^2+1}}[/tex]
This can be split up into two integrals, and in this case, the second integral will go to 0. So we have
[tex]\int_{C}{\frac{e^{iz}dz}{z^2+1}}\rightarrow \int_{-\infty}^{+\infty}{\frac{e^{ix}dx}{x^2+1}}[/tex]
And your integral can be found as the real part of this.
Ahh! Thanks, that does make sense now. In my haste such a simple observation eluded me! You can see clearly why I am not cut out for contour integration. I will attack the problem with this new integrand now.
Thanks again,
QM
  • · Replies 27 ·
  • · Replies 29 ·
  • · Replies 19 ·
