Orthogonal Basis for Subspace: Find Solution
  • Thread starter Thread starter hpayandah
    Basis Orthogonal
The problem involves finding an orthogonal basis for a subspace defined by the equation 2x - y + z = 0. The original poster presents two vectors, X1 and X2, and describes their application of the Gram-Schmidt process to achieve orthogonality.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to apply the Gram-Schmidt process to the given vectors. One participant questions the calculation of a specific coefficient, while another confirms the correctness of the original poster's approach.
The discussion is active, with participants engaging in clarifying specific calculations and confirming the accuracy of the presented work. There is no explicit consensus on the correctness of the original poster's vectors, as one participant points out a potential error in the notation.
There is a mention of a possible misrepresentation of one of the vectors in the original post, which may affect the overall understanding of the problem.
hpayandah
Hi Everyone,
I want to ask if I did this problem correctly.
Find a orthogonal basis for subspace {[x y z]T|2x-y+z=0}
X1= [3 2 -4]T, X2=[4 3 -5]T
Gram-Schmidt:
F1=X1= [3 2 -4]
F2= X2- ((X2.F1)/||F1||2)F1= [4 3 -5]T + (26/29)[3 2 -4]T
Thanks in advance.
Hi hpayandah! :smile:
I don't quite get how you obtained the 26 in the end. Could you explain? (Maybe I just miscalculated it).
Hi, Thanks for replying, it's the result of:
(X2 . F1) / (||F1||2)
Attached is my work.
Yes, that is correct. You wrote X2 wrong in the OP :smile:
Appreciated.
  • · Replies 16 ·
  • · Replies 24 ·
