A question about Volume charge density and electrostatic equilibrium
The discussion centers on the relationship between volume charge density and electrostatic equilibrium. Volume charge density, measured in C/m³, represents an even distribution of charge in a three-dimensional space, while electrostatic equilibrium dictates that charge resides solely on the surface of conductors. The participants conclude that volume charge density is a theoretical concept, as real materials, even lossy ones, will rearrange charge to the surface when an electric field is applied. The conversation emphasizes that charge density can vary within a material, contradicting the notion of uniform distribution.
  • Understanding of electrostatics and electric fields
  • Familiarity with charge density concepts
  • Knowledge of conductors and dielectrics
  • Basic principles of resistive materials and their behavior in electric circuits
  • Research the properties of conductors versus dielectrics in electrostatics
  • Explore the mathematical implications of volume charge density in theoretical physics
  • Study the behavior of electric fields in lossy materials
  • Learn about the dynamics of charge movement in resistive materials
Students of physics, electrical engineers, and anyone interested in the principles of electrostatics and charge distribution in materials.
Lanza52
The concept of volume charge density is an even distribution of charge over a three dimensional area. C/m^3. However, the concept of electrostatic equilibrium says that all of a conductors charge lies on the surface of the conductor.
The existence of one seems, to me at least, to render the other pointless... Anything less then a perfect non-conductor would nearly instantly rearrange the charge towards the surface. So a volume charge density is a purely theoretical construct that will never exist. So any application of it is just in practice to demonstrate the math.
Am I missing something?
Most materials are not perfect conductors.
The question is even it is not a perfect conductor...even a lossy material, as long as electrons can flow, any electric field inside the material will cause the electrons(charges) to flow and neutralize the field.
This is like you put a potential across a high value resistor ( say 10ee12 ohm), the moment you remove the voltage source, the potential across the resistor will immediately goes to zero. The resistor will not maintain the voltage ( field ) across by itself, electrons will stop flowing and no field is left.
For dielectric with very low conductance, it might take longer time for the charge to move to neutralize the internal field, but it will eventually.
This is actually a very good question.
To the OP, volume charge density do not imply even distribution. Charge density can vary from point to point inside.
  • · Replies 27 ·
