Newton's Laws question : On springs and pulley system
The discussion focuses on the conditions for a particle attached to a spring on a rough inclined plane to oscillate. It establishes that for oscillation to occur, the coefficient of friction, μ, must be less than 1/3 times the tangent of the angle of elevation, θ. The equilibrium position is defined as x_e = (mg(sin θ + μ cos θ)) / k, where k is the spring constant. The analysis concludes that if friction dissipates all the energy before reaching this equilibrium position, oscillation will not occur.
  • Understanding of Newton's Laws of Motion
  • Knowledge of spring mechanics and Hooke's Law
  • Familiarity with friction concepts and coefficients
  • Basic algebra for solving equations involving forces and motion
  • Study the derivation of oscillation conditions in spring-mass systems
  • Explore the effects of friction on motion in inclined planes
  • Learn about energy conservation principles in mechanical systems
  • Investigate advanced topics in harmonic motion and damping
Students of physics, mechanical engineers, and anyone interested in understanding oscillatory motion in systems involving springs and friction on inclined planes.
The Stallion
A Particle is attached by a string to a point in a rough inclined plane of elevation [itex]\theta[/itex]. Co-efficient of friction is [itex]\mu[/itex]. Originally, the string is unstretched and lay along the line of greatest slope.Prove that the condition for particle to oscillate is [itex]\mu[/itex] < 1/3tan[itex]\theta[/itex].
Note : Tension in the string = [itex]\lambda[/itex].[itex]\Delta[/itex]l/l
[itex]\Delta[/itex]l = Change in length
l = Original length
If friction steals away all the energy of the particle before it reaches at most an equilibrium position of [itex]x_e=\frac{mg(sin \theta +\mu cos\theta)}{k}[/itex], where xe is the distance from the starting position of the particle and k is the spring constant, then there is no oscillation. The equilibrium position is gotten by solving:
[tex]mgsin \theta +\mu (mg cos\theta)-kx_e=0[/tex]
Then solve:
[tex]\mu (mg cos\theta) x_e<\frac{1}{2}k (x_e)^2+mg (x_e sin \theta)[/tex]
by substituting in the expression for xe to get the condition for oscillation.
  • · Replies 24 ·
  • · Replies 22 ·
