Solve Crazy Lagrange Problem: Min Distance from Origin
  • Context: Graduate
  • Thread starter Thread starter daBish
    Lagrange
The discussion focuses on solving the constrained optimization problem of finding the minimum distance from the origin using the Lagrange method, specifically with the constraint equation z² - xy + 1 = 0. The Lagrangian function is defined as L(x,y,z,λ) = f(x,y,z) - λg(x,y,z), where f(x,y,z) = x² + y² + z² and g(x,y,z) = z² - xy + 1. The solution involves taking partial derivatives and setting them to zero, leading to a system of equations that ultimately yields k = ±2 as a critical value for further calculations. The complexity of this problem emphasizes the need for a solid understanding of Lagrange multipliers and constrained optimization techniques.
  • Understanding of Lagrange multipliers
  • Familiarity with constrained optimization techniques
  • Knowledge of partial derivatives
  • Basic proficiency in multivariable calculus
  • Study the application of Lagrange multipliers in various optimization problems
  • Learn how to derive and solve systems of equations from partial derivatives
  • Explore advanced mathematical techniques for solving complex optimization problems
  • Practice similar constrained optimization problems to reinforce understanding
Students and professionals in mathematics, engineering, and economics who are dealing with optimization problems, particularly those involving constraints and the Lagrange method.
daBish
Ok this is the question I had on a test today:
given this constraint equation z^2-xy+1=0 find the min. distance from the origin using Lagrange method.
so basically you use D^2=x^2+y^2+z^2 as the other equation. however, it basically goes nuts from there. especially if you set it up like you are suppose to.
Fx=(lambda)Gx
Fy=(lambda)Gy
Fz=(lambda)Gz
g=0
(capitals are partial derivatives)
with f as the distance formual and g as the constraint
this one sucks but if someone could help it would be greatly appreciated
Minimizing D is the same as minimizing D^2, so we solve
2x = -ky
2y=-kx
2z=2kz
whence k=1, x=-y, which leads to nonsense, or z=0, and 2x=-ky=k^2x, so k=sqrt(2), also note that xy=1, and the solution follows.
edit, thanks to arildno, it should read:
2x=-ky=k^2x/2, ie
4x=xk^2, whence k=+/-2
from which you should be able to get the answer.
The Lagrange method is a powerful tool for solving constrained optimization problems, but it can be quite challenging to apply, especially in more complex problems. In this case, we are trying to find the minimum distance from the origin, subject to the constraint z^2-xy+1=0. This means that we are trying to minimize the function f(x,y,z) = x^2 + y^2 + z^2, while satisfying the constraint g(x,y,z) = z^2-xy+1=0.
To solve this problem, we first set up the Lagrangian function L(x,y,z,λ) = f(x,y,z) - λg(x,y,z). This function represents the trade-off between the objective function (minimizing distance) and the constraint (satisfying the given equation). The parameter λ is known as the Lagrange multiplier, and it helps us incorporate the constraint into our optimization problem.
Next, we take the partial derivatives of L with respect to x, y, z, and λ, and set them equal to 0. This will give us a system of equations that we can solve to find the optimal values for x, y, z, and λ. Once we have these values, we can plug them back into the original objective function to find the minimum distance from the origin.
However, as you mentioned, this problem can get quite complicated and may require some advanced mathematical techniques to solve. If you are struggling with it, I would recommend seeking help from a tutor or classmate who may have a better understanding of the Lagrange method. It's always a good idea to practice solving similar problems beforehand, so you can be better prepared for the test. Good luck!
