Optics - Diopter farsighted + shortsigted
  • Thread starter Thread starter zimo
    Optics
The discussion focuses on calculating the view range of a man who is both farsighted and shortsighted, with a natural viewing distance between 70cm and 100cm. The calculated diopter for his farsightedness is D=2.571, leading to a maximum view range of 25cm to 38.889cm when using reading glasses. A debate arises regarding whether to use 1/100cm or 1/∞ in the equation for determining the view range, with the consensus leaning towards using 1/100cm to reflect the man's maximum visible distance.
  • Understanding of optical physics, specifically lens equations
  • Familiarity with diopter calculations and their implications
  • Knowledge of the concepts of farsightedness and shortsightedness
  • Basic algebra skills for solving equations
  • Study the lens maker's equation for different types of lenses
  • Learn about the effects of corrective lenses on vision
  • Explore the relationship between diopter values and focal lengths
  • Investigate common optical formulas used in vision correction
Optometrists, physics students, and anyone interested in understanding the principles of optics and vision correction.
zimo
A man is both farsighted and shortsighted so his natural correct view is between 70cm to 100cm.
What will be his view range if he puts on his reading glasses?
[tex]\frac{1}{u}+\frac{1}{v} = \frac{1}{f} = D[/tex]
I calculated diopter for his farsightness and came with D=2.571 (1/0.25 - 1/0.70 = 2.571
Now, I wanted to know what will be the his maximum range and have come to the equation:
[tex]\frac{1}{u}-\frac{1}{\infty} = 2.571[/tex]
And the solution for u is 38.889cm, so the view range will be between 25cm to 38.889cm.
Now, there is another opinion in our class that when I use the equation to reveal the limit to his view range I should put 1/100cm instead of [tex]\frac{1}{\infty}[/tex] because the man can see to 100 cm at max and not to the extent of the horizon.
What is the correct way and why?
Thank you
the reading lens should have power such that for object at near point of vision (25cm) its image should form at 70cm ... so that eye lens can focus it.
find power of it that way ...
now for far point ... when object is at u ... its image should be at 100cm ... so solve for u (answer)
10K
  • · Replies 23 ·
