Signal attenuator controllable by UDP,TCPIP?
  • Thread starter Thread starter paul120
    Signal
The discussion focuses on automating a signal attenuator for simulating digital television picture breakup due to low signal levels. The user proposes using a USB TV receiver connected to a signal attenuator with a serial input for software control. Suggestions include building a serial to parallel interface and possibly using a BCD converter to facilitate communication between the PC and the attenuator. Digital attenuators are highlighted as a viable solution based on past experiences in RF applications.
  • Understanding of digital television signal processing
  • Familiarity with USB TV receivers
  • Knowledge of serial communication protocols
  • Experience with RF signal attenuation techniques
  • Research digital attenuator options compatible with serial control
  • Learn about building serial to parallel interfaces
  • Explore BCD (Binary-Coded Decimal) conversion techniques
  • Investigate software libraries for controlling hardware via serial communication
Students in electronics or telecommunications, hobbyists interested in RF signal manipulation, and engineers developing automated signal processing systems.
paul120
Hello as part of a degree project I need to simulate digital television picture breakup, as demonstrated when the signal level is low or interferred with. I have found manual attenuators which are quite cheap but I need to automate the process with software on a pc. Is there anyway possible of acheiving this?
I envisage a pc running a usb tv receiever, the aerial coax cable plugged into a signal attenuator, the signal attenuantor having a serial input which allows the attenuation to be controlled via software on the PC. the software side is not an issue, merely the harware.
Many thanks
Digital attenuators were common place when I was doing RF. May need to build a simple serial to parallel interface, maybe with a convertor to BCD. These should be available surplus, based upon the magnitudes of quantity that I have seen scrapped.
