| New Reply |
When I was little I loved thumb sucking. It was so comforting. But, |
Share Thread | Thread Tools |
| Jul15-11, 10:17 AM | #1 |
When I was little I loved thumb sucking. It was so comforting. But, then one day I stopped thumb sucking. It was forced upon me in a brutal way, but I got rid of the habit. I was very angry at the perpetrator but eventually I got used to life without sucking my thumb. Discuss the deep philosophical implications and revealing truths about human nature that are contained in this opening post.
| Jul15-11, 11:28 AM | #2 |
Mentor
Parents should never allow thumb sucking to begin with.
| Jul15-11, 12:17 PM | #3 |
| Jul15-11, 12:23 PM | #4 |
Mentor
| Jul15-11, 12:23 PM | #5 |
Perhaps I suffer from thumb sucking deprivation syndrome??
| Jul15-11, 12:48 PM | #6 |
Mentor
| Jul15-11, 01:46 PM | #7 |
| Jul15-11, 02:03 PM | #8 |
| Jul15-11, 02:10 PM | #10 |
| Jul15-11, 02:27 PM | #11 |
Does one pull the thumb (or fist, or toe) out of the mouth of the babe-in-arms? |
| Jul15-11, 02:39 PM | #12 |
| Jul15-11, 02:42 PM | #13 |
I had lost my two bottom baby teeth naturally, but customized the process by riding my bicycle into a parked car so that I was missing all four bottom front teeth at the same time. When they grew back in, one was squeezed to the rear. Since the spacing seemed pretty good when the rest of my permanent teeth came in, getting braces to squeeze the rear tooth back into place didn't seem to serve much purpose, so they just pulled it. In retrospect, I should have kept it as a spare. At least it was protected by my other teeth and less likely to get knocked out. |
| Jul15-11, 02:50 PM | #14 |
Mentor
| Jul15-11, 03:01 PM | #15 |
| Jul15-11, 03:32 PM | #16 |
| Jul15-11, 03:33 PM | #17 |
Even the ADA only worries about thumb sucking (from a orthodontic/medical view) once permanent teeth are coming in. The reason you want to try and change this behavior earlier is that it is easier to change. There will be no permanent damage to the mouth from thumb sucking before the permanent teach come in. There are some worries about communication development at preschool age, but typically children give up the habit at this age also. So it is not usually an issue. Pacifiers and thumb sucking are normal. The same sort of issues can occur with pacifier use as with thumb sucking. It should be said also, that non-nutritive sucking (i.e. thumb sucking) in infants is important. It can help promote suckling and proper feeding, reduces pain, and may be extremely important to premature babies. |
| New Reply |
| Thread Tools | |
Similar Threads for: When I was little I loved thumb sucking. It was so comforting. But,
| Scientists sue to stop 'black hole' from sucking up Earth | General Discussion | 2 | ||
| Does my Thumb warp spacetime? | Special & General Relativity | 3 | ||
| Rule of thumb | General Physics | 5 | ||
| After you cut your thumb | General Discussion | 48 | ||
| [SOLVED] Sucking water from vacuum! | Introductory Physics Homework | 9 | ||
