Convergent subsequences in compact spaces
  • Context: Graduate
  • Thread starter Thread starter redbowlover
    Compact Convergent
The discussion revolves around the properties of compact spaces, particularly focusing on the relationship between sequential compactness and limit point compactness. Participants explore whether there exist compact spaces that are not sequentially compact and discuss implications for proper maps in topology.
  • Some participants assert that any sequence in a compact metric space has a convergent subsequence, while any compact topological space is limit point compact, leading to the question of whether compact spaces can be non-sequentially compact.
  • One participant provides a counterexample using the topology of finite complements on the natural numbers, demonstrating that this topology is compact but not sequentially compact.
  • Another participant questions the definition of a proper map, suggesting it involves the preimage of compact sets being compact, and inquires about additional conditions on the space X.
  • Some participants suggest using filters or nets instead of sequences to potentially resolve the problem, while others express a preference for a sequence-based approach due to familiarity.
  • There is a discussion about the nature of limit points in the finite complement topology, with one participant noting that every point is a limit point of the sequence in that topology.
  • Another participant clarifies that while the finite complement topology is limit point compact and compact, it is not sequentially compact, emphasizing the distinction between these properties.
Participants generally agree on the definitions of compactness and limit point compactness but disagree on the implications and examples related to sequential compactness. The discussion remains unresolved regarding the existence of compact spaces that are not sequentially compact.
Limitations include the potential misunderstanding of the properties of the finite complement topology and the distinction between first-countable and non-first-countable spaces. The discussion also reflects varying levels of familiarity with concepts such as nets and filters.
redbowlover
My quick question is this: I know it's true that any sequence in a compact metric space has a convergent subsequence (ie metric spaces are sequentially compact). Also, any arbitrary compact topological space is limit point compact, ie every (infinite) sequence has a limit point.
So in general, are the compact spaces that are not sequentially compact?
This is part of a larger problem: If a real-valued function on a topological space X is proper, show the image of f is closed. My idea was to chose a limit point y of f(X) and a sequence f(x_n) in f(X) converging to Y. Cover this sequence by a closed interval I. The the preimage of I is compact and contains the sequence x_n. Now, x_n has a limit point, say x.
If I could show f(x)=y, I'd be done. But i get stuck without being able to use sequential compactness.
THanks ahead of time
Yes, sequentially compactness has nothing to do with compactness in general topological spaces. A counterexample is given by the topology of finite complements. Take [itex]\mathbb{N}[/itex] equipped with the topology
[tex]\mathcal{T}=\{A\subseteq \mathbb{N}~\vert~\mathbb{N}\setminus A~\text{is finite}\}\cup \{\emptyset\}[/tex]
Then the sequence
[tex]0,1,2,3,4,5,...[/tex]
does not have a convergent subsequence. (in fact, the only convergent sequences in this topology are the one which eventually become constant).
What is proper with you? I imagine it's something like "the inverse images of compact sets are compact", but do you also demand things like surjective??
And are there conditions on X, like Hausdorff?
You can probably save your argument using filters or nets, instead of sequences :smile:
for me a proper map is a continuous map such that the preimage of a compact set is compact. Unfortunately there is no extra conditions on X.
and since I've never worked with nets before, a net-free solution would be best :-) I went with a sequence route because I know it works for proper maps from R^n to R...
OK, the key idea is the following:
If [itex]A_i[/itex] is a collection of subsets of X such that its interiors cover X, and if each [itex]f\vert_{A_i}[/itex] is closed, then f is closed.
Use properness to find such a collection of [itex]A_i[/itex]'s.
thanks...i'll think about this
This might be a good time to start -- one of the best ways to learn a concept is to see how it is used to extend the reach of other notions you understand.
Wouldn't the use of nets be artificial here, tho? Metric spaces are 1st-countable,
so sequences work to detect continuity and convergence.
But we're not working in a first countable space here. Otherwise, I would agree with you!
You're right, micromass; I read when s/he mentioned a metric space X, and I
thought that is what the ref. was about.
Micromass Jul 15 3:11 pm:
Yes, sequentially compactness has nothing to do with compactness in general topological spaces. A counterexample is given by the topology of finite complements. Take N equipped with the topology
T={A⊆N | N∖A is finite}∪{∅}Then the sequence
0,1,2,3,4,5,...does not have a convergent subsequence. (in fact, the only convergent sequences in this topology are the one which eventually become constant).
But:
Isn't every point a limit point of this sequence (any open set containing an arbitrary point contains all points beyond some point of the above sequence)? This is example 18 (1) of Counterexamples in Topology by Steen & Seebach.
Then the sequence
0,1,2,3,4,5,...
But:
Yes, so?
The finite complement topology is limit point compact and compact, but not sequentially compact. That's all I wanted to show here. If you want a space that's limit point compact, but not compact, you'll need some other example.
  • · Replies 17 ·
