Solving for Forces on an Inclined Suitcase
  • Thread starter Thread starter IGeekbot
The problem involves analyzing the forces acting on a suitcase being pulled at a constant speed on an incline. It includes determining the angle of the handle with respect to the horizontal and calculating the normal force acting on the suitcase.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the implications of "constant speed" and how it relates to the forces involved. Questions arise regarding the calculation of the angle and the normal force, with some suggesting trigonometric relationships and others questioning the assumptions about vertical and horizontal forces.
Some participants have provided insights into the calculations, including separating the force into components and considering the balance of forces. There is a mix of interpretations regarding the normal force and the angle, with no explicit consensus reached on the correct values.
Participants mention constraints such as missing lecture content and varying interpretations of the problem setup, particularly regarding the forces acting on the suitcase and the implications of constant motion.
IGeekbot
I have no clue what to do on this problem. it is
Rachel pulls her 18kg suitcase at a constant speed by pulling on a handle that makes an angle with the horizontal. The frictional force on the suitcase is 27N and Rachel exerts a 43N force on the handle.
A) what angle does the handle make with the horizontal?
B) what is the normal force exerted on the suitcase?
Where do I start?
What does "constant speed" imply?
Thanks for the help, but i solved this eventually with my lab partner. I missed the lecture unfortunately, but i am up to speed now.
can you please post answers?? is the normal force 20 N? how did u find the angle?? did you use Tan-1 ( Opp/adj ) ?? if so , what how did u find the opp and adj angle..
thanks
isnt normal force = 18g ? and the angle is cos inverse of (27/43) ? what i did is 43cosx = 27 for the angle ... and mg = normal force. Is this correct ?
the force 43 N can be separated into the horizontal component (43cosx) and the vertical component (43 sinx).
Since it is constant motoin, so 43cosx=27, cosx=27/43, x=51.1 degrees.
But the suitcase is only doing horizonal motion, not vertical motion (it is not moving up and down...), so the two vertical forces (mg ,and the force on the suitcase by the floor) must be cancelled. the downward force: mg=18x9.8=176.4 N which should be equal to the upward force, but now 43sinx=43 sin (51.1degrees)=33.4 N ,which is much less than 176.4N,
so the unbalanced force 176.4-33.4=143N is the normal force...
we can also find out the coefficient of friction of the floor since friction=uN, where u is the coefficient and N is the normal force, now the normal force is 143N, so we can know that u=friction/N=27/143=0.19
  • · Replies 24 ·
20K
9K
