Object rotation in vacuum and the Friction force
The discussion revolves around the behavior of rotating objects in a vacuum, specifically addressing the implications of friction forces, energy conservation, and the effects of gravity on rotation. Participants explore theoretical scenarios involving rigid and non-rigid bodies, as well as the relationship between vacuum conditions and gravitational forces.
  • Some participants assert that no friction force applies to an object rotating in a vacuum, suggesting it would continue to rotate indefinitely.
  • Others argue that "in vacuum" does not imply the absence of all friction, particularly between the object and its axis of rotation.
  • Concerns are raised regarding non-rigid objects, which may experience stress and energy loss due to outward acceleration, potentially affecting their rotation.
  • Participants discuss the implications of special relativity on rigid bodies, referencing the Ehrenfest paradox and the potential for rigid bodies to shatter when rotated.
  • There is mention of gravitational forces not being eliminated in a vacuum chamber, indicating that gravity and vacuum are separate concepts.
  • Some participants propose that a perfectly symmetrical object rotating in a vacuum would not lose energy and could rotate indefinitely if not influenced by external forces.
  • Questions are raised about the behavior of two bodies in a free-falling vacuum chamber and whether they would rotate around each other.
Participants express multiple competing views regarding the presence of friction in a vacuum and the conditions under which an object may stop rotating. The discussion remains unresolved, with differing opinions on the effects of rigidity, symmetry, and external forces on rotational motion.
Limitations include assumptions about the nature of friction in vacuum conditions, the definition of rigid versus non-rigid bodies, and the implications of gravitational forces in relation to rotation.
niralsoni
Any object rotating on the axis does stop because of some kind of friction force.
What happens if the same object rotates in the vacuum ?
does the friction force applies to it ?
or does it stop at any point in time ?
or does it continue to rotate forever ?
Thanks & Regards,
Niral Soni
1) no friction force applies to it
2) it won't stop at any time
3) yes it will rotate forever
example:- earth, moon
"In vacuum" does not necessarily mean no friction! If you have an object rotating around an axis and rotating around that axis, there will be friction between the object and the axis.
(Thanks for the correction.)
If the object is not rigid it will cause stress due to the outward acceleration. I don't know if this necessarily will cause deformation and thus slowing the rotation, but I am quite certain that some mechanical energy will be lost because of this.
If the object is completely rigid, then special relativity has something to say about that: http://en.wikipedia.org/wiki/Ehrenfest_paradox
There are some problems with rigid bodies rotating because of length contraction. Apparantly a rigid body will immediately shatter if it is rotated, or so the article explains is one proposal.
Rigid rotating rods however, I think they would rotate forever.
The Earth and moon not such a good example, since e.g. the moon cause tidal flow on Earth which is a huge source of friction, and this does indeed slow rotation. Earth itself by rotating cause friction within the layers of the ground, and this is as well draining the mechanical energy of rotation.
HallsofIvy said:
"In vacuum" does not necessarily mean no friction! If you have an object rotating around an axis and rotating around that axis, there will be friction between the object and the friction.
HoI...I think I see what you are saying, but this is a very, very strange way of saying it.
I think there was a typo and the last word should be "axis".
thanks all of you for the quick reply.
what i understand from this discussion that there will be a friction force beteen the object and its axis, which in turn at some point in time will stop that object rotation.
please correct me if i am wrong.
Now, Can we relate vacuum with the zero gravity ?
what happens to the object rotating in outer space where there is a zero gravity?
And, say for example, in a vacuumed container, a rotating object is placed. Will there be any gravitational force applies to that object?
Thanks & Regards,
Niral Soni
A vacuum chamber does not eliminate gravity. They are not related concepts.
ok..
A torque is required to change angular momentum. For example, the Earth's rotation rate is gradually decreasing because the Moon exerts a torque on the Earth via the tides. Without no external torques acting on some object, that object's angular momentum will be conserved.
Angular velocity, however, is not a conserved quantity, nor is mechanical energy. A non-rigid but still cohesive body will eventually wind up rotating about the axis with the greatest moment of inertia.
sorry i didnt get it...most objects in universe rotate around imagenry axis so how can there be friction between both...will u please explain
So would you say that a planet unaffected by external forces would rotate indefinitely, without regard to friction caused by the rotation itself?
If the object that is rotating is not perfectly symmetrical about its rotation axis then it will emit gravitational waves and lose energy that way. Neutron stars are expected to do this for example.
The original question said nothing about lack of gravity or lack of a supporting axis.
than you sir for your reply. But this gives me one more doubt. Does this means that your saying that if perfectly symmetrical object rotates around itself will never loose its Energy and keep on rotating forever
If it is floating out in space and not connected to anything, yes. Conservation of energy demands that if nothing saps energy from it, it won't lose its rotational kinetic energy.
oh thnx now i got it what you meant
Considering the perfect symmetrical object rotating on its axis in vacuum, will it be possible to create a model arround it, here on the Earth ?
If I put 2 bodies in a free falling vacuum chamber, will they rotate around each other ?
Apologies if the question is dumb.
  • · Replies 35 ·
  • · Replies 67 ·
  • · Replies 37 ·
