Vanishing surface charge density on current-carrying wire?
The discussion centers on the surface charge density on a long, straight, cylindrical current-carrying wire as described in the paper by Coombes and Laue. The expression for surface charge density, cz/R = (-Eε₀ / (Rln(L/R)))z, indicates that as the length L approaches infinity, the surface charge density approaches zero at any point z. However, participants argue that while pointwise convergence to zero occurs, the maximum surface charge density in the mid-section of the wire does not vanish, contradicting the paper's conclusion. The analysis suggests that the assumption of linear variation in surface charge density leads to misleading interpretations regarding the behavior of electric fields and Poynting flow around the wire.
  • Understanding of electromagnetic theory, particularly surface charge density concepts.
  • Familiarity with the mathematical expressions involving electric fields and logarithmic functions.
  • Knowledge of Poynting's theorem and its application in electromagnetism.
  • Experience with cylindrical coordinate systems in physics.
  • Study the derivation of surface charge density in cylindrical geometries using Maxwell's equations.
  • Examine the implications of pointwise versus uniform convergence in mathematical physics.
  • Explore the relationship between surface charge density and Poynting vector flow in electromagnetic fields.
  • Review A. Sommerfeld's "Electrodynamics" for historical context and foundational principles in electromagnetism.
Physicists, electrical engineers, and students of electromagnetism who are analyzing current-carrying conductors and their associated electric fields. This discussion is particularly relevant for those investigating the nuances of surface charge behavior in theoretical and practical applications.
shoestring
In a paper by Coombes and Laue (http://docs.google.com/viewer?a=v&q...sig=AHIEtbQDQ3xeLo4PPx99CKlE3P6i4YWybw&pli=1") an expression, labelled (8), for the surface charge density cz/R on a long, straight, cylindrical current-carrying wire is given as
[tex]cz/R = (-E\epsilon_0 / (R\ln{(L/R)}))z[/tex]
R i the radius, assumed to be << L.
E is the interior (longitudinal) electric field, driving the current.
The wire occupies the interval [-L,L] on the z axis, and the net charge is assumed to be zero. The surface charge density is a linear function of z, and for a given interior field E and radius R, the slope of the function depends inversely on ln(L/R), i.e. the slope gets weaker for larger L.
The expression is valid for z << L, i.e. the mid section of the wire.
In the paper it's pointed out that
"As L --> infinity, this surface charge density goes to zero at any given point z."
but then comes the interesting part, where it's stated that
"... an infinitely long wire in which a steady current is flowing has a vanishing surface charge density (8) and a uniform electric field both inside and outside the wire. It is particularly noteworthy that as L --> infinity the electric field outside the wire has a vanishing component normal to the wire."
something I find questionable.
The expression (8) is only assumed valid for z << L, so let's confine the argument to, say, the mid 1% of the wire and ignore the rest:
Now, no matter how big you choose L, you won't get a vanishing surface charge density on the mid section (which will always be 1/100 of the total length, i.e. it too will grow as L grows).
In other words, even if you have a pointwise convergence to zero as L grows to infinity, I wouldn't agree that the surface charge density on the wire goes to zero as L grows to infinity. No numerical value of L, no matter how large, will make the surface charge density function arbitrarily small on even the mid one percent of the wire. Quite the contrary, the maximum surface charge density on the (growing) mid 1 percent will go to infinity as L goes to infinity, so you shouldn't say that the surface charge density on the wire goes to zero. This isn't a case of uniform convergence to the zero function, only of pointwise convergence.
According to a critical comment on the paper (included in the link) the result of the paper can also be found in A. Sommerfeld's Electrodynamics (Academic, New York, 1952) which is described as "one of the classic treaties of the literature on electromagnetism." Nevertheless I think it's wrong, and that it's an obvious mistake to rely on pointwise convergence in this case. Any thoughts? Am I wrong?
I didn't want to make the first post too long, so here are a few more thoughts on the issue:
The right way to calculate the surface charge density on a long, straight current-carrying wire (ignoring effects from charge distributions on other parts of the circuit) would be to calculate the surface charge density on a long (but finite) cylinder placed in a uniform electric field, with the cylinder's main axis along the direction of the field. If a conductor is placed in a uniform electric field, the induced surface charge will create a uniform interior field that inside the conductor exactly cancels the external field. For the cylinder that means that the surface charge will create exactly the kind of interior electric field that would drive a current through the cylinder.
Such calculations are difficult though, and the assumption that the surface charge density varies linearly along the cylinder turns out to create the uniform internal field you'd expect to drive the current through the wire, at least some distance from the endpoints.
That's what is done in the Coombes & Laue paper. They start with the assumption that the surface charge density varies linearly along the wire, and calculate the linear coefficient as a function of the interior field E and the radius R of the wire. Hopefully this gives a decent estimate of the surface charge density for |z| << L.
As has been said, the slope of the linear function describing the surface charge density gets weaker for larger values of L, so there'll be an increasing interval around the middle having a surface charge smaller than a certain value, but even if the absolute size of the interval grows, it'll constitute an increasingly smaller fraction of the wire. Because of that I think it's wrong to draw the conclusion that the surface charge density on the wire goes to zero as L goes to infinity.
The surface charge density is directly related to the outer radial electric field, so the surface charge density will also be related to the size and direction of the Poynting flow just outside the wire.
If it is as is concluded in the paper that the wire's surface charge density vanishes when L grows, then the Poynting flow just outside will be purely radial and directed towards the wire. If, on the other hand, there is a non-vanishing surface charge density, the Poynting flow near the wire will be larger and have a component parallel to the wire, at least almost everywhere along the wire.
