Kinetic frction between the hamburger and the ramp
  • Thread starter Thread starter bballgirlweez
    Kinetic Ramp
The discussion centers around a physics problem involving a giant hamburger sliding down a ramp inclined at 45 degrees. The coefficient of kinetic friction between the hamburger and the ramp is given as 0.597, and the net force acting on the hamburger is specified as 6.99 x 10^3 N. Participants are tasked with determining the mass of the hamburger and the normal force exerted by the ramp.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss various methods to resolve the net force into components, questioning how to derive the mass and normal force from the given information. Some suggest drawing free body diagrams and working backwards from known forces, while others express confusion over the formulas and their applications.
The discussion is ongoing, with participants exploring different interpretations of the problem and attempting to clarify the relationships between the forces involved. Some have provided guidance on how to approach the problem, while others are seeking further explanations and validation of their reasoning.
Participants are working under the constraints of a homework assignment, which may limit the information available and the methods they can use. There is also a noted confusion regarding the application of formulas and the definitions of variables involved in the problem.
bballgirlweez
physics help pleasezzzzz
Suppse a giant hamburger slides down a rampt aht has a 45 degree incline. The coefficient of kinetic frction between the hamburger and the ramp is .597, so that the net force actiong on the hamburger is 6.99 x 10^3 N. What is the mass of the hamburger? What is the magnitude of the normal force that the ramp exerts on the hamburger?
Work 'Backwards'
Instead of finding the vector sum of the various forces acting on the body, you are given the resultant force and asked to resolve it into all of its various components. So, draw the FBD and work backwards from what you know. You know the applied force and the angle, so you can resolve it into components perpendicular and parallel to the incline. The perpendicular component is the normal force. The parallel component is the net force on the burger in the direction down the ramp. What contributes to it? The // component of the weight. What takes away from it? The friction force. Find the latter, use it find the former. You can then solve for the weight.
just for my info, is 1194 kg the mass of it??
coz i did Ff=u+fn
6990=.597+ 9.8m ( since fn = mass x gravity )
6990/.597=9.8 m
m = 1194...
is that correct?
Sorry, I don't understand what you are doing there. Could you maybe explain where the formula came from? Thanks! :smile:
bball girl you need to show some of your work first.
Jai remember that:
F_f=uN
6.99 x 10^3 is the resultant force, not the force of friction.
well that's a formula i learnt..
Ff=Uk + Fn ... ( Force of friction = Coefiicient of Kinetic friction x Normal Force )
Jai remember that:
F_f=uN
F_f= uN
can u please tell me what the variables in the above equation stand for?
is f_f - frictional force?
u - coefficient
N = normal force?
Thanks much for ur assistance..
after reading the question again, this is my thought process:
Fnet= 6990 N
Uk = .597
the following are the equatoins i have actually learned
F = ma
Fapp-Ff=ma
Ff=uk+Fn
i can't seem to substitute these values in the above equations to get the answer .. maybe if i only can find the acceleration so that i could substitute it in the F=ma equation to get the mass...
DAMN! I've done this chapter last year and am again doing it this year and i still can't get a simple problem.. :'(
There is a way to get the acceleration of the hamburger...
Since [tex]\ F_a_p_p - F_f = ma[/tex]
and
[tex]\ F_a_p_p = sin45(9.8m)\ and\ F_f = 0.597(9.8m)[/tex]
The applied force was found from the parallel component of the force of gravity acting on the hamburger.
So...
[tex]\ F_a_p_p\ - F_f = ma[/tex]
Sub in the values...
[tex]sin45(9.8m)\ -\ 0.597(9.8m) = ma[/tex]
Now notice that the masses cancel out and you are left with acceleration. Solve for acceleration and sub that into the [tex]\ F_n_e_t = ma[/tex] equation.
The answer I came up with was 6472.2 kg
I haven't done this in a year or so, it would be good if someone could check it.
hmm i think your solution might be correct but its on an incline so there has to be a horizontal component of the force app too i think...
Well, the [tex]\ sin45m[/tex] is the component of the force of gravity acting parallel to the ramp. The only other component is perpendicular to the ramp which creates the friction. The component of the force parallel to the ramp is the only one that needs to be looked at for force applied (remember that the force applied comes from gravity).
[tex]ma = F_g + N + F_f[/tex]
[tex]6.99 * 10^3 N = |{(mg sin 45 + -umg)\vect{i} + (mg - mg cos 45)\vect{j}}|[/tex]
[tex]6.99*10^3 N = \sqrt{ (mg(sin 45 - u))^2 + (mg(1-cos 45))^2} = .312906mg[/tex]
[tex]6.99*10^3 N/ (.312906*9.81 \fract{m}{s^2}) = m = 2276.77 kg[/tex]
N = mg (in the axis lines parrellel with the plane F.O.R.)
N = mg cos 45 (in the base of the ramp as the axis F.O.R.)
9K
  • · Replies 56 ·
