Calculating Minimum Batted Ball Speed for Homerun at Fenway Park
The discussion focuses on calculating the minimum batted ball speed required for a homerun at Fenway Park, specifically over the 12m high "Green Monster" fence located 100m from home plate. The ball is hit at an angle of 35° above the horizontal from a height of 1.0m. Key equations used include the kinematic equation v² = u² + 2as for vertical motion and the decomposition of initial velocity into horizontal (Vx = Vo cos 35°) and vertical components (Vy = Vo sin 35°). The vertical velocity at the height of the fence is derived from gravitational acceleration, leading to a systematic approach to determine the initial velocity needed for the homerun.
  • Understanding of projectile motion principles
  • Familiarity with kinematic equations
  • Basic knowledge of trigonometry, specifically sine and cosine functions
  • Experience with solving equations involving multiple variables
  • Study the derivation of projectile motion equations in physics
  • Learn how to apply kinematic equations to real-world scenarios
  • Explore the effects of different launch angles on projectile trajectories
  • Investigate the impact of initial height on the required initial velocity for projectiles
Physics students, sports analysts, and anyone interested in the mechanics of baseball and projectile motion will benefit from this discussion.
hobo
When David Ortiz hit a homerun over the 12m high "Green Monster' fence at Fenway park 100m away from home plate, the ball was hit 1.0m above the ground at an angle of 35° above horizontal. What was the minumum speed of the batted ball?
dx = 100m
Vx = Xcos35°
Vox= Xcos35°
ax = 0
dy = 11m
vy = ?
voy = ?
ay = -9.8m/s/s
t = ?
That is as far as I have gotten. I have only had experience with three missing variables, not five. How do I even start this question?
Suppose we make the initial velocity Vo. Then the initial x direction velocity is Vocos(35) and the y is Vosin(35). Can you write an equation for the displacement in the x and y directions based on your acceleration and initial velocity?
If you're assuming that its path is parabolic and you are using some of the simple physics formulae then:
v^2= u^2 + 2as
(take out 'u^2' because you are calculating the vertical velocity once it reaches 1 meter above the ground after having accelerated from the point above the fence where it's vertical velocity component was equal to zero)
v(vertical component) = sqrt(2 x acceleration due to gravity x 11)
then you could work in the V(initial) = V_y (initial)/ sin 35 etc. etc.
  • · Replies 23 ·
15K
