Domain/range of functions inverse
The discussion revolves around finding the inverse of the function f(x) = (x+1)^2, graphing both the function and its inverse, and determining the domain and range of the inverse. Participants are exploring the implications of the function not being one-to-one and how that affects the existence of its inverse.
  • Participants discuss the range of f(x) and question how to determine the domain of its inverse, particularly regarding the implications of negative values. There are attempts to clarify the method for finding ranges of rational functions, including the use of derivatives.
The discussion is ongoing, with various participants questioning the validity of methods presented for finding ranges and the implications of the function not being one-to-one. Some guidance has been offered regarding the relationship between derivatives and range, but there is no consensus on the effectiveness of the methods discussed.
Participants are navigating assumptions about the function's properties, particularly its one-to-one nature, which affects the determination of its inverse. There are also references to the limitations of certain methods for finding ranges, suggesting a need for caution in their application.
Nelo
For the following function find the inverse of f(x) graph the inverse and f(x) and determine the domain and range of its inverse
f(x) = (x+1)^2
f(x)inverse = (plusminus) [sqrt] x-1
I know the range for f(x)
but how is the domain for the inverse x is greater than or equal to 0? It passes to the negetive side...
I have both graphs, but i don't understand how to get the domain and range... How can
What is "it"?
To find range for rational functions:
1. Find the derivative of the function
2. Set the derivative equal to zero and solve
3. Plug values back into original equation
4. Omit complex results if your working in the set of real numbers
GreenPrint said:
To find range:
If the above makes no sense at all then I assume all your expected to do is just think about it to get your answer. I hate that method though.
It makes no sense to me. Try it on f(x) = x3.
*adds in "for rational functions" and takes out note*
f(x) = (x+1)^2
But your "inverse" isn't a function since it gives two values. Technically, your given function doesn't have an inverse because it isn't 1-1.
So how does your method apply to f(x) = 1/x?
f(x) = (x+1)^2
You realize that since f(x) is not one-to-one, f-1(x) is NOT a function, right?
You're looking at the y-values (assuming you graphed correctly.) Yes, some y-values of the graph of f-1(x) are negative, but you need to look at the x-values when dealing with the domain.
I don't know about you, but I had to learn about domains and ranges a year before I learned how to take derivatives. So I don't think this method is going to help.
It will work for continuous ranges. If the derivative is 0 then at that point the function is not growing or falling. The range will always be from one point where f'(x) = 0 to another point where f'(x) = 0. Your example grows without bound, so it's from some number to infinity.
Derivative is 3x^2
3x^2 = 0
x = 0
Since that's the only solution, it's the only real domain limit. Since solving for and x greater than 0 yields a greater y, x = 0 is the lower range, 0 cubed is 0, domain is 0, infinity.
Or another example:
y = 5x^2 + 7x + 5
y' = 10x + 7
10x + 7 = 0
x = -7/10
x = -7/10 is the only real solution.
5(-7/10)^2 + 7(-7/10) + 5
= 2.55
Range is [2.55, infinity)
More useful for examples that don't just grow without bound.
[itex]y=\frac{4x+1}{x^2+x+1}[/itex]
Derivative:
[itex]-\frac{4x^2+2x-3}{(x^2+x+1)^2}[/itex]
0 = 4x^2 + 2x - 3
x =
[itex]\frac{-2+\sqrt{52}}{8}[/itex]
[itex]\frac{-2-\sqrt{52}}{8}[/itex]
Solving for those x in original equation:
Range is [-3.070, 1.737]
moved to calculus and beyond
1MileCrash said:
It will work for continuous ranges. If the derivative is 0 then at that point the function is not growing or falling. The range will always be from one point where f'(x) = 0 to another point where f'(x) = 0. Your example grows without bound, so it's from some number to infinity...
This looks to me like an ad hoc method that sometimes, maybe usually, works. But there are probably unstated exceptions or additions to the method. If
[tex]f(x) = \frac{x^2}{x^2+4}[/tex]
the derivative is 0 when x = 0 and only there. How does your method give the range (without adding more cases to the "method")?
That's not a range where the function will actually equal the limiting range at a point. This function approaches 1.
Derivative method will find 0 as the beginning of the range because the function actually equals zero at a point.
That's my point. You are suggesting a method that supposedly works on rational functions with continuous range but it is apparently an incomplete method. It is just a tool that might be helpful on some functions, but maybe not on others, even if they are rational functions.
No, I am just explaining to you a method that someone else posted. You remarked that it made no sense, so I showed the sense of it.
Finding where derivative = 0 shows maximum and minimum values, it's not a leap of logic that it helps with finding the ranges of a function as well.
It will work, for any continuous function, that has a range that would be in brackets on both ends. I'm pretty sure that's correct, anyway. For any noncontinuous function, I'd think breaking it up into intervals would work fine.
Point taken. It's late and I haven't kept track of who posted what first.
Yes, I agree that can be a useful tool in some cases. GreenPrint posted it at the beginning of this thread presented it as though it was "the way" to do the problem. There's more to it, that's all I'm saying. Anyway, time to hit the sack here.
  • · Replies 22 ·
  • · Replies 23 ·
