How Do You Find the Inverse of a Radical Function?
The problem involves finding the inverse of a radical function, specifically the function y = √(x² + 9). Participants are discussing the steps and reasoning involved in this process.
  • Participants are examining the correct interpretation of the function and the steps needed to find its inverse. There are questions about the initial setup and the proper use of parentheses in the expression. Some participants are clarifying the process of swapping variables and solving for y.
The discussion is active, with participants providing guidance on how to approach the problem. There are multiple interpretations of the function's structure being explored, and some participants are questioning the original poster's reasoning and steps taken.
There is a noted confusion regarding the placement of parentheses in the function, which affects the interpretation of the radical. Participants are also discussing the implications of squaring both sides of the equation in the context of finding the inverse.
Nelo
Find the inverse of each of the following functions
y= [sqrt] x^2 + 9
y = [sqrt] x^2 +9
x= [sqrt] y^2 +9
x-3= y
I did the sqrt of 9, and sqrted y and its wrong.
The answer is apparently y=+/(plusminus) [sqrt]x^2 -9 .. How do you solve this?
anyone?
Hi Nelo! :smile:
(have a square-root: √ and try using the X2 icon just above the Reply box :wink:)
Nelo said:
y = [sqrt] x^2 +9
x= [sqrt] y^2 +9
How did you get that second line? :confused:
Its an inverse...
No it isn't. :redface:
Write it out in full before trying to invert it. :smile:
Nelo said:
y= [sqrt] x^2 + 9
Need some parentheses. I don't know if you mean
[itex]y = \sqrt{x^2} + 9[/itex]
or
[itex]y = \sqrt{x^2 + 9}[/itex]
Nelo said:
y = [sqrt] x^2 +9
x= [sqrt] y^2 +9
x-3= y
Looks like the 9 is INSIDE the square root. You got it completely wrong from line 2 to line 3. From line 2, square both sides, and then subtract the 9. Then solve for y.
There are two commonly taught ways to find inverses of functions:
1) First solve y= f(x) for x, then swap x and y.
2) First swap x and, y, then solve for y.
So given [itex]f(x)= \sqrt{x^2+ 9}[/itex], you can write that, first, as [itex]y= \sqrt{x^2+ 9}[/itex] then swap x and y to write [itex]x= \sqrt{y^2+ 9}[/itex].
However, it is not true that [itex]\sqrt{a^2+ b^2}= a+ b[/itex]. For example, [itex]\sqrt{9+ 16}= \sqrt{25}= 5[/itex], not [itex]\sqrt{9}+ \sqrt{16}= 3+ 4= 7[/itex].
In order to solve [itex]x= \sqrt{y^2+ 9}[/itex] for y, start by squaring both sides.
  • · Replies 23 ·
