Potential between two parallel planes
The discussion focuses on finding the electric potential between two parallel planes located at x=0 and x=L, with boundary conditions defined as Φ(x=L)=Φ₀|sin(ky)| and Φ(x=0)=0. The user initially proposed a solution involving exponential and trigonometric functions but encountered a published solution that utilized a cosine series expansion for |sin(ky)|. The key takeaway is that the Laplace equation is satisfied by each term in the series expansion, leading to the differential equation d²Cₙ/dx²=(2kn)²Cₙ, which is essential for determining the coefficients in the series.
  • Understanding of Laplace's equation and its applications in electrostatics.
  • Familiarity with boundary value problems in partial differential equations.
  • Knowledge of Fourier series, particularly cosine expansions.
  • Basic concepts of potential theory in physics.
  • Study the derivation and applications of Fourier series in solving boundary value problems.
  • Learn about the method of separation of variables in partial differential equations.
  • Explore the properties of Laplace's equation and its solutions in electrostatics.
  • Investigate the significance of boundary conditions in determining unique solutions to differential equations.
This discussion is beneficial for physics students, particularly those studying electromagnetism, as well as mathematicians and engineers dealing with partial differential equations and boundary value problems.
noamriemer
Hello ! I have an exam this Wednesday... your help will be appreciated...
There are two types of questions I can't figure out how to answer...
the first is this one:
Find the potential between two parallel planes. The first is in x=0, the second in x=L.
[itex]\Phi(x=L)=\Phi_0 |sin(ky)|[/itex]
and
[itex]\Phi (x=0)=0[/itex]
What I thought I should do is look for a solution of the sort:
[itex]X(x)=Ae^{\sqrt{k^2+l^2}}+Be^{-\sqrt{k^2+l^2}}[/itex]
[itex]Y(y)=Csin(ky)+Dcos(ky)[/itex]
[itex]Z(z)=Esin(lz)+Fcos(lz)[/itex]
Then, I should start checking which of the terms should vanish.
But when I looked at the published solution, it was completely different:
[itex]|sin ky|=\sum_{n=0}^{\infty}{A_ncos(2kny)}[/itex]
[itex]\rightarrow |sin(ky)|=\frac{2}{\pi}+\sum{\frac{4}{\pi(1-4n^2)}}cos(2kny)[/itex]
So now we seek a solution for Laplas eq. this way:
[itex]\Phi(x,y)=C_0x+\sum_{n=1}^\infty{C_n(x)cos(2kny)}[/itex]
and:
[itex]\frac{d^2}{dx^2}C_n =(2kn)^2C_n[/itex]
I don't understand this solution at all.
Why should one expand this function, |sin(ky)| ?
and what is the last equation:
Thank you so much!
and
That isn't the most general solution to Laplace's equation (which with your factorization reverts to: [itex]X^{''}/X + Y^{''}/Y + Z^{''}/Z = 0[/itex]:
[itex]X'' = aX[/itex], [itex]Y''=bY[/itex], [itex]Z''=cZ[/itex], [itex]a+b+c=0[/itex].
Your set of solutions doesn't cover the case where say [itex]a=0, b+c=0[/itex]. You can try to enumerate every combination of cases but it is better to start with your boundary conditions for some guidance. You see that [itex]Y(y)[/tex] is going to be non-trivial and start there.<br /> <br /> It looks like the published solution simply expresses the expansion of Y solutions using coefficients which are functions of the other independent variable(s) and re-applies the Laplace equation.<br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> But when I looked at the published solution, it was completely different: <br /> <br /> [itex]|sin ky|=\sum_{n=0}^{\infty}{A_ncos(2kny)}[/itex]<br /> <br /> [itex]\rightarrow |sin(ky)|=\frac{2}{\pi}+\sum{\frac{4}{\pi(1-4n^2)}}cos(2kny)[/itex]<br /> <br /> So now we seek a solution for Laplas eq. this way:<br /> <br /> [itex]\Phi(x,y)=C_0x+\sum_{n=1}^\infty{C_n(x)cos(2kny)}[/itex]<br /> and:<br /> [itex]\frac{d^2}{dx^2}C_n =(2kn)^2C_n[/itex]<br /> <br /> I don't understand this solution at all. <br /> Why should one expand this function, |sin(ky)| ?<br /> and what is the last equation: <br /> [itex]\frac{d^2}{dx^2}C_n =(2kn)^2C_n[/itex]<br /> <br /> Thank you so much! </div> </div> </blockquote>Firstly since the boundary conditions and original equation are symmetric under z translation the solution is independent of z.<br /> <br /> The text is expanding solutions of [itex]Y^{''}=bY[/itex] in terms of the cosine expansion of the boundary condition (using the fact that it is an even function of y and independent of z). (One might also have tried a hyperbolic cosine expansion if the boundary condition where even and asymptotically exponential. Cosh is the even component of exp.)<br /> <br /> By the linearity of Lap.Eqn. Each term in the expansion [itex]\Phi(x,y) = C_0(x) + C_1(x)\cos(2ky) + \cdots[/itex], must independently satisfy Laplace's eqn.<br /> <br /> You get that last equation for all terms even the first term where n=0 which is the exceptional case I mentioned above.<br /> <br /> Matching your attempt:<br /> [itex]\Phi(x,y) = \sum_{some\,a,b} X_a(x)Y_b(y),\quad a+b=0[/tex]<br /> [itex]=\sum_n C_n(x)\cos(2kny)[/itex]<br /> with [itex]b = -(2kn)^2[/itex] and so [itex]a = (2kn)^2[/itex].[/itex][/itex]
Thank you for the detailed answer!
  • · Replies 30 ·
