Real Analysis: Continuity and Uniform Continuity
The discussion revolves around the continuity and uniform continuity of the function f(x) = (x^2)/((x^2)+1) on the interval [0, infinity). Participants are exploring the definitions and implications of continuity in the context of real analysis.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are attempting to apply the delta-epsilon definition of continuity but are encountering difficulties in determining appropriate delta values. There is also a discussion about the implications of the derivative on uniform continuity.
Some participants are actively questioning their understanding of the definitions of continuity and uniform continuity, with one participant suggesting that the definitions may have been confused. There is an ongoing exploration of how to demonstrate continuity and uniform continuity for the given function.
There is a mention of needing to show continuity using the delta-epsilon definition, and some participants express uncertainty about the behavior of the function's derivative in relation to uniform continuity.
danielkyulee
Question: Show that f(x)= (x^2)/((x^2)+1) is continuous on [0,infinity). Is it uniformly continuous?
My attempt: So I know that continuity is defined as
"given any Epsilon, and for all x contained in A, there exists delta >0 such that if y is contained in A and abs(y-x)<delta, then abs(f(x)-f(y))<Epsilon.
So i tried expanding the function, but still can not find the values for delta that make this continuous on [0,infinity). Any ideas?
Also, it is NOT uniformly continuous correct?
Thanks!
well its definitely continuous on [0,inf) - can you show that?
now for the "uniform continuity part", not as the actual proof, but I would consider the derivative - it should give you an idea of how to approach the problem
loosely speaking if a function is uniformly continuous it shouldn't have a derivative that misbehaves
consider
[tex]|\frac{f(y)-f(x)}{y-x}|[/tex]
in the limit y goes to x, this becomes the derivative...
Hey, so one of the problem I had was that I could not find a way to show it was continuous. I tried to show it using the delta-epsilon definition of continuity, but couldn't figure out a way to find delta.
ok so where did you get stuck?
So i did absolute(f(x)-f(y))= abs( ((x^2)/((x^2)+1)) - ((y^2)/((y^2)+1)) ). I simplified this to get abs( ((x^2)-(y^2))/((x^2)+1)((y^2)+1)) ).
Now I tried to set it up so that abs ( x-y ) is less than 1 (which would be one of the minimum components of delta) so that I can try to abs( x-y ) less than something with respect to epsilon. However, I am stuck on how I can use <1 to find the deltas that make abs( f(x)-f(y) ) < E for any given E.
Thanks!
I believe you have your definitions backwards. A function is continuous at a point x if given epsilon there is a delta. If you pick some different point y, then given the same epsilon, you may need a different delta.
If the same delta works for a given epsilon regardless of x, that is uniform continuity.
What you wrote above is the definition of uniform continuity ... given epsilon, for any x there's a delta. The def of continuity is that given x, for any epsilon there is a delta that depends on x.
  • · Replies 40 ·
  • · Replies 27 ·
  • · Replies 21 ·
  • · Replies 26 ·
