MATLAB - Sophisticated Image Processing/Rendering
  • Thread starter Thread starter GreenPrint
    Image Matlab
The discussion centers on using MATLAB for sophisticated image processing and rendering, specifically with MRI data. The key solution involves utilizing the 'clf' command to clear figures before plotting new data, which is essential for achieving the expected results. The user successfully implemented this after referencing the tutorial on the MathWorks website, particularly the 'reducevolume' function. This approach highlights the importance of following MATLAB's documentation for effective visualization techniques.
  • Familiarity with MATLAB programming environment
  • Understanding of MRI data visualization techniques
  • Knowledge of MATLAB plotting functions, including 'isonormals'
  • Basic grasp of command-line operations in MATLAB
  • Explore MATLAB's 'reducevolume' function for advanced image processing
  • Learn about the 'isonormals' function and its applications in 3D plotting
  • Investigate additional MATLAB commands for figure management, such as 'clf' and 'hold on'
  • Review MATLAB's official documentation on image processing and visualization techniques
Researchers, engineers, and students involved in medical imaging, particularly those working with MATLAB for MRI data analysis and visualization.
GreenPrint
THIS WAS SOVLED
My book did a very bad job explaining the matter. I have no idea what function(s) I should even use to solve this problem using the MRI data that comes with MATLAB
An MRI visualization example is shown in the help tutorial. Copy and paste the commands into an M-file and run the example. Be sure to add the clf command before drawing each new plot.
I'm suppose to add the clf command to get the results the question is expecting from me. I missed around with the code and the only way I could a result different than from the original code was by adding it right after the isonormals function, this is the tutorial it's making refernce to and the code can be found at the bottom http://www.mathworks.com/h​elp/techdoc/ref/reducevolu​me.html
THANKS
i was able to solve the first part so i got rid of it
