N-butyl alcohol and bromide reaction
  • Thread starter Thread starter kellyN
    Alcohol Reaction
The reaction of n-butyl alcohol with potassium bromide in the presence of concentrated sulfuric acid and water involves the formation of hydrobromic acid (HBr) through the protonation of bromide ions by sulfuric acid. This reaction follows an SN2 mechanism, where the hydroxyl group of n-butyl alcohol is protonated by HBr, allowing the bromide ion to perform a backside attack on the primary carbon, resulting in the formation of 1-bromobutane. Sulfuric acid acts as a catalyst and provides hydrogen ions for protonation, while water serves as a solvent, albeit a protic one that can slow the reaction.
  • Understanding of SN1 and SN2 reaction mechanisms
  • Knowledge of protonation and nucleophilic attack
  • Familiarity with the role of catalysts in chemical reactions
  • Basic concepts of solvent effects in organic chemistry
  • Study the detailed mechanism of SN2 reactions with primary substrates
  • Research the role of sulfuric acid in organic synthesis
  • Learn about the effects of protic solvents on reaction rates
  • Explore the synthesis and properties of 1-bromobutane
Chemistry students, organic chemists, and anyone interested in reaction mechanisms and the role of acids in organic transformations.
kellyN
n-butyl alcohol was reacted with potassium bromide in the presence of concentrated sulphuric acid and water.
1) Is hydrobromic acid involved in this reaction? If yes, how so?
2) Is this reaction SN1 or SN2? What is the mechanism?
3) What is the purpose of the sulphuric acid and water?
1) I believe HBr is involved, even though it's not added. Perhaps the bromide from potassium bromide and the hydrogen ion from sulphuric form HBr.
2) This is an SN2 reaction (substrate is a primary carbon). The hydroxyl group of the n-butyl alcohol undergoes protonation with HBr, while the nucleophilic Br- does a backside attack on the carbon atom which is attached to the alcohol group. The leaving group is the water molecule while n-butyl alcohol is converted into 1-bromobutane.
3) Sulphuric acid serves as a catalyst? Or to provide the hydrogen ions for protonation.. or for the formation of HBr? Quite confused over this question. Water seemingly serves as a solvent, but it's a protic solvent, which means that it will slow the reaction down. Why is this so?
Any help would be greatly appreciated. Thanks in advance.
Yes, in an acidic environment, your nucleophile will be neutral (in a basic environment, it'll be an anion). The sulfuric acid protonates the KBr to give HBr.
Yes, it's SN2. The rest looks fine.
The sulfuric acid pushes the hydroxyl equilibrium toward protonated hydroxyl, setting up water as a good leaving group. HBr is a pretty decent nucleophile in water, given that the hydrogen bonding to HBr is quite a bit weaker than in other acids like HCl or HF.
  • · Replies 28 ·
9K
