Problem with solve two differential equations.
The discussion focuses on solving two differential equations involving a material property, y (density), and mesh velocity, v, with respect to time and displacement. The equations are ∂(yv)/∂t=f(y,v,t) and ∂v/∂h=constant, where h represents an element length in finite element analysis. The user seeks clarification on whether y is a variable and if f(y,v,t) is a known function. The goal is to determine the values of y and v at each time step.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with finite element analysis (FEA)
  • Knowledge of material properties in fluid dynamics
  • Experience with numerical methods for solving differential equations
  • Research methods for solving partial differential equations numerically
  • Learn about finite element analysis techniques for dynamic systems
  • Explore the implications of variable material properties in fluid dynamics
  • Investigate specific functions for f(y,v,t) in the context of PDEs
Researchers, engineers, and students in fields such as fluid dynamics, computational mechanics, and applied mathematics who are working with differential equations and finite element methods.
hoomanya
Hi,
I am trying to solve the two equations cited below but not sure if it is possible to solve them...
∂(yv)/∂t=f(y,v,t)
where v is velocity = dx/dt, and y is a material property.
In addition:
∂v/∂x = constant
Any hints would be appreciated.
Many Thanks!
Well... i would like to help, but there are some things i could not understand.
Is y a constant, or it is a function of v, t, or some other variable?
Is f(y,v,t) a given (known) function? (like f(y,v,t)=sin(y+v*t) for example)
And what are the variables you are trying to solve for?
Hi,
y is a variable , say density and changes with time.
v is mesh velocity and and x is displacement. When I said ∂v/∂x = constant, I meant ∂v/∂h = constant, where h could be thought of as an element length in finite element. I'm not sure if that would make a difference.
I am trying to solve for y and v at each time step.
Thank you very much.
  • · Replies 19 ·
  • · Replies 32 ·
