Question which one travels faster?
  • Context: High School
  • Thread starter Thread starter kashmirekat
The discussion revolves around a physics problem involving two balls: one thrown downward from a building and another thrown upward with the same initial velocity. Participants explore the speeds of the balls upon impact with the ground and the distance between two balls dropped at different times. The conversation includes theoretical reasoning, assumptions about air resistance, and interpretations of the problem statements.
  • Homework-related
  • Christina initially believes the ball thrown upward will hit the ground faster due to gaining more speed after reaching its peak height.
  • Some participants argue that both balls will hit the ground with the same speed, assuming no air resistance and equal initial kinetic energy.
  • One participant points out that the first ball, having been thrown downward, will have more time to accelerate, thus increasing the distance between the two balls dropped at different times.
  • Another participant emphasizes that the distance between the two balls increases because they are both accelerating at the same rate, but the first ball has a head start.
  • There is a discussion about the assumptions made, such as neglecting air resistance and the initial conditions of the balls.
  • Mathematical reasoning is introduced to explain the increasing distance between the two balls over time.
Participants do not reach a consensus on the speed of the balls upon impact, with some asserting they hit at the same speed while others support the idea that the ball thrown downward travels faster. The discussion about the distance between the two balls dropped at different times also remains unresolved, with differing interpretations of the problem.
Assumptions regarding air resistance and the initial conditions of the balls are critical to the discussion, and participants express varying interpretations of the problem statements, which may lead to different conclusions.
kashmirekat
Question...which one travels faster?
I had this question on a homework assignment and I was hoping someone could help me understand why I got it wrong.
A ball is thrown down from a building and another ball is thrown up with the same amount of velocity. What is their speed when they hit the street?
a. the one thrown up is traveling faster
b. the one thrown down is traveling faster
c. the speeds are the same
d. cannot be determined
The answer I chose was [a] because it is going to travel up until the velocity reaches zero at which point it will fall a greater distance (therefore gaining more speed on the way down) than that of the ball initally thrown down.
Please correct me if I am wrong and tell why. Thank you and have a nice day!
Christina
I'm slightly confused, is the second ball thrown upwards from the top of the building or from ground level?
Anyway assuming that the second ball is thrown from the top of the builing, ignoring terminal velocity, yes it will hit the street faster as (assuming the inital velocity, u = 0) for v, velocity, a acceleration and s distance:
v = as
for both of them a = g (accelartion due to gravity)
therefore the larger s (in tis which should be defined as the distance fallen) the large v.
So yes you're correct, the answer you want is a)
Yes, the second ball was thrown from the building.
Thank you! I thought I was correct and I was peeping at other folks' papers and they all chose 'the same speed', and got it right mind you. I find that interesting.
Another question I got wrong was a ball (ball A) is dropped from a building, one second later another ball (ball B) is dropped from the same building. What is the distance between the two balls?
a. remains constant
b. increases
c. decreases
I chose a. remains constant. They are both falling at the same rate, they are going to gain the same acceleration on the way down with only a second difference. Ball A will hit the ground first, but ball B will hit one second later. The answer my instructor gave was 'b. increases'. I just don't understand how the distance could increase when the rate they are falling is the same.
Christina
Remember the first ball to be thrown will always be traveling at a greater speed compared to the second ball as it would of had more time to accelerate, so the distance between the two is always getting larger.
jcsd, as you suggest by mentioning terminal velocity all these problems depend so much on one's assumptions
with my assumptions I seem to get a different answer
I assume air resistance is ignored, the building is like in a vacuum(!)
and that both balls are thrown from the roof (where they have the same potential energy) and given the
same kinetic energy
so they both start out with the same amount of energy
so I think of them as having the same when they hit ground
I was thinking of them as identical balls but it doesn't matter
if one's bigger since its really just energy per unit mass that's the same
I think so, too, marcus.
edit: bah, I misread the problem. I was thinking the ball thrown up was being thrown up from the street. Yeah, they both land at the same speed. [hangs head in shame]
Remember that, neglecting air resistance, a ball thrown up has the same speed it had on the way up at each height on the way down. Thus when it returns to the top of the building it will have the same velocity as the other ball, therefore it hits the ground with the same velocity.
Christina,
it is very pleasant to have a physics problem like these in the morning, so thanks for contributing. Bring in some more like these if you have them!
Advice: if you don't understand the replies keep asking questions.
About the first question: Sonty (a romanian student) says the answer is C-----they hit with the same speed.
If you don't see why, ask him! It would be good practice for him to explain.
About the second question: JCSD says the answer is B-----the distance caused by a one-second delay increases with speed. If you don't understand ask him to explain further.
There is also a Homework Help section of this board. This is a great board. We also have great crazies. You should visit us daily.
:wink:
post script: oops also Integral the local mentor Honcho has replied----you are getting red carpet treatment!
The reason this NOT correct is that, while the second ball is "gaining more speed on the way down", it starts downward (from its highest point)at 0 velocity while the first ball started downward with an initial velocity.
If the problem had said the first ball were DROPPED while the second ball was thrown upward, you would be correct.
The really important question is "what is the velocity of the second ball when it is again at the original position (on its way down)?"
The answer is thatt they both land at the same speed, assuming their initial speeds were the same and no air resistance. How?
Use the energy calculation.
Final KE = Initial GPE + Initial KE.
Notice that initial GPE is the same for both balls.
Also notice that KE = 0.5 * mv^2 - and is independent of + or - velocity.
Therefore, the final KE of both is the same, and so both land at the same speed. The time of landing is very different, of course.
I understand the first problem I asked. However, I am still not fully understanding the one with ball a dropped and then ball b dropped one second later. When they hit the ground, ball a will hit first, and then ball b will hit one second later, right? So how could the distance between them increase? Ball A accelerates faster, true because it was dropped first. However, Ball B accelerates at the same velocity (the pull of gravity) as that of A, only a second behind. I know that over a period of time objects falling fall faster. But when ball A increases its acceleration downward at a certain time, ball B also increases its acceleration downward at a later time of one second.
Sorry if this sounds trivial, but I'm just trying to understand. Thank you for all of your help.
Christina
Well, you know that the objects are undertaking linear acceleration, right?
This means that you have a straight line graph in V against time, and to find the distance, you take the area under that. Correct?
Now you know from the linear acceleration that final velocity = kt, where k is some constant. (I'm not going to use exact values, just given a feel of the quality of behaviour). And that the total distance traveled is equal to A (another constant) * v * t
Hence, we get the idea that the distance traveled is proportional to the square of the time.
Now, the difference in distance between the two is then proportional to (where x is the time delay)...
= B * ( T^2 - (T-x)^2)
= B* (T^2 - T^2 - x^2 + 2*T*x)
= B * 2 * T * x - B * x^2
And T is time, obviously the difference in distances increases.
hmmm, you see I considered the first ball to be dropped not thrown, I realize now that I misread the question.
I had to read the question several times and then read some responses before figured out what the question was. Seems to be rather poorly worded.
I fully understand now. Thank you all for your help. Sorry for any poor wording, I didn't have the assignment with me and tried to remember the basis of what the question asked.
I feel so special.
I do believe I will do that. You people are very insightful and helpful in answering my questions. I have another homework assignment so I will probably be posting on the homework board for further assistance.
Thanks again for everyone's help. I understand. Nothing tops that. :)
  • · Replies 49 ·
  • · Replies 46 ·
  • · Replies 236 ·
18K
