New Reply
Calculating angle of a rotation for a line
Share Thread Thread Tools
Jul21-11, 12:22 PM   #1
Hi Guys,
I want to rotate a line so that it lies on the positive x direction. I can determine the equation of the line as y=m*x+c where m is the slope and c is the intercept. The angle of rotation, theta is known by tan inverse of m. Now theta can be either -theta or -(pi+theta) depending on the quadrant in which the line lies.
How can I know which of these thetas i should use directly by looking at the equation of the line. I need to rotate about 400 lines so manually looking at each line can be time intensive. I can use an if else loop in my code to do it automatically.
Thanks.
Nancy
PhysOrg.com
PhysOrg
mathematics news on PhysOrg.com
>> Mathematicians analyze social divisions using cell phone data
>> Can math models of gaming strategies be used to detect terrorism networks?
>> Mathematician proves there are infinitely many pairs of prime numbers less than 70 million units apart
Jul21-11, 12:34 PM   #2
Do you mean a line, or a ray? If you're dealing with a line, then rotating by -theta-pi produces exactly the same result as rotating by -theta. It's only if you're dealing with a ray (or, say, rotating a line segment about one end) that the ambiguity you mention becomes significant.
Every floating point library I know of has a two-argument form of the arc tangent function, arctan(x,y) or ArcTan(x,y) or atan2(x,y), that finds the angle whose tangent is y/x. This two-argument form returns the theta that is right for the quadrant of (x,y), and also deals correctly with the x=0 case (although I gather that's not a problem for you).
You can also do the rotation directly, without ever explicitly calculating the angle. This is the most efficient way.
Jul21-11, 12:40 PM   #3
Hi pmsrw3,
Yes I am rotating a line about one point. I translate all the line segments that I am studying to the origin. I want to rotate all the lines so that they fall on the positive X axis. I am using MATLAB. So I need to determine the correct angle for rotation, if not I get segments on the positive and negative axis.
Jul21-11, 12:51 PM   #4
If I understand you right, this is much simpler than you think. If you have a line segment from (0,0) to (x,y) and you rotate it about the (0,0) end so that it's horizontal, you will always end up with (l,0) as the new distal endpoint, where [itex]l=\sqrt{x^2+y^2}[/itex] is the length of the line segment. There's no need to compute the angle of rotation at all.
New Reply
Tags
rotation
Thread Tools
Similar Threads for: Calculating angle of a rotation for a line
Thread Forum Replies
Angle of Twist and Rotation Engineering, Comp Sci, & Technology Homework 1
Change in angle due to rotation Differential Geometry 0
Angle rotation about 2 axes Differential Geometry 1
Rotation in R2, around a line? Calculus & Beyond Homework 0
rotation angle Calculus & Beyond Homework 3
