Approximating Integrals with Deriv & Discont: Help Needed!
The discussion revolves around approximating an integral that involves a derivative of a function and is evaluated over a discontinuity. Participants explore the implications of the discontinuity on the integral's existence and potential approximations, considering the behavior of the functions involved.
  • One participant presents an integral involving a derivative and a discontinuity, suggesting that an exact solution may not exist but is seeking an approximation.
  • Another participant argues that the Riemann integral does not exist due to the non-existence of the derivative at the point of discontinuity, highlighting that the integral's value could vary depending on how the discontinuity is approached.
  • A different participant agrees that more information is needed and suggests that the integral over the derivative alone is defined, but questions how the presence of the discontinuous function g affects the situation.
  • Further discussion raises the point that the key difference between the integrals of f' and f'/g is the discontinuity of g at the same point as f, which complicates the limit process.
  • Some participants propose that if g can be expressed as the derivative of another function, it might influence the analysis, but there is no consensus on its impact.
Participants express differing views on the existence of the integral and the implications of the discontinuity. There is no consensus on how to approach the problem or the validity of the proposed approximations.
Participants note the dependence of the integral's value on the nature of the limiting series of functions and the specific behavior of the functions around the discontinuity. The discussion highlights unresolved mathematical steps and assumptions regarding the functions involved.
zhermes
I'm trying to do an integral, in which the integrand is composed of arbitrary functions and contains a derivative of the variable of integration. Further still, the integral is over a discontinuity. Because these are arbitrary functions I assume there is no exact solution, but I'm looking for an approximation.
Anyway, there is a discontinuity at 'x'
[tex] \lim_{\Delta x \to \infty} \int_{x-\Delta x}^{x+\Delta x} \frac{1}{g(r)} f'(r) dr[/tex]
The functions are defined in the limits on each side of the discontinuity, i.e.
[tex] \lim_{\Delta x \to 0} \hspace{0.3in} f(x+\Delta x) = A \hspace{0.3in} f(x-\Delta x) = B \hspace{0.3in}<br /> g(x+\Delta x) = C \hspace{0.3in} g(x-\Delta x) = D[/tex]
Thus, if the integrand did not contain g(r), the result would be simple (from Leibniz's rule)
[tex] \lim_{\Delta x \to \infty} \int_{x-\Delta x}^{x+\Delta x} f'(r) dr = A - B[/tex]
Any help, tips, or pointers would be greatly appreciated!
Thanks,
Z
I don't think there's enough information to answer. Obviously, the Riemann integral formally doesn't exist, since f' doesn't exist at x. If one imagines f as the limit of a series of functions in which the region within which the change from A to B occurs gets smaller and smaller, then the value of the integral will depend on the nature of the limiting series. This is obvious, because one could have all the change occur on the minus side, in which case the integral will be (A-B)/D, or you could have it all occur on the plus side, in which case the integral will be (A-B)/C. Yet in both cases the limit of the series is the same discontinuous function f.
I think I understand the basis of your point, but it seems as though it should apply to the integral over f'(r) itself [i.e. without the 1/g(r)]; but that integral is indeed defined [i.e. (A-B)].
Further, the only difference is that g is not a derivative. But I think, given the particular situation, one could say that:
[tex] g(x) \equiv h'(x)[/tex] [tex] \lim_{\Delta x \to 0} h(x+\Delta x) = h(x - \Delta x) = h_0[/tex]
Does that help / change anything?
"The only difference" between what and what?
The key difference between f' and f'/g is that g is discontinuous, and it is discontinuous at the exact same point as f. My argument doesn't apply to f' (or even to g, if C = D), because a limiting series of functions that converges to f will give the same integral for f', whether f changes from A to B below x or above x. It it only when f is multiplied by another function that is discontinuous exactly at x that this limit fails.
Not in any way that I can see.
  • · Replies 24 ·
