How Do Electric Fields Interact at Specific Points on the Y-Axis?
The discussion revolves around calculating the electric field generated by two point charges located on the x-axis at specific points on the y-axis. The original poster attempts to determine the electric field at a point 0.48 M on the y-axis due to two positive charges positioned at 1.06 M and -1.06 M on the x-axis.
  • Participants discuss the method of summing electric field vectors and the importance of considering the direction of the unit vectors when calculating the total electric field. There is a focus on the cancellation of x components of the electric fields due to the symmetry of the charge placement.
Some participants have provided guidance on the need to account for the direction of the electric field vectors and the cancellation of components. The discussion is ongoing, with participants exploring different aspects of the problem without reaching a consensus on the correct approach.
There is an emphasis on understanding the unit vector that points from the charge to the point of interest, which is crucial for correctly calculating the electric field. The original poster expresses uncertainty about their calculations and seeks clarification on the method.
nemzy
Two 2.06e-6 C point charges are located on the x axis. One is at 1.06 M and the other is at -1.06 M
(a) Determine the electric field on the y-axis at .48 M
This is how i did it:
Etotal=sum of E vectors...
E=ke*q/r^2
r^2=1.06^2+.48^2
q=2.06e-6
E1 = Ke*q/(1.06^2+.48^2)
E2= same thing
E1+E2 = total..
answer is wrong..what am i doing wrong
Both charges are positive. The electric field equation is given by
Kq/r^2 * r-hat, which is a unit vector pointing radially away from the charge.
If you draw a picture of the two e-fields, you'll see that the components don't add exactly (in fact, the x components cancel out), so you need to take that into account.
yeah when i was trying to do this i just realized that too..but i still don't nkow how to find the electric field
You should ask yourself: what is the unit vector, r-hat, that points from the point charge to the coordinate in consideration?
IE, for one point charge, what is the unit vector that points from (1.06, 0) to (0, 0.48)? Knowing this, you can express the unit vector r, in terms of cartesian coordinates, and you should see, that when you add the E-fields together, the x-hat components cancel.
  • · Replies 16 ·
