Am I using interfaces in Fortran correctly?
  • Context: Comp Sci
  • Thread starter Thread starter ASGtFT
    Fortran
The discussion centers on a compilation error encountered while using the NAG Fortran Compiler Release 5.2 with interfaces in Fortran. The error arises from the subroutine 'my_sub' in 'subroutines.f90', which conflicts with the interface defined in the 'test_mod' module. The issue is due to the naming conflict between the subroutine and the interface, which leads to ambiguity during compilation. To resolve this, the user must rename either the subroutine or the interface to eliminate the conflict.
  • Understanding of Fortran programming language syntax
  • Familiarity with NAG Fortran Compiler Release 5.2
  • Knowledge of Fortran modules and interfaces
  • Basic debugging skills in Fortran
  • Research Fortran module and interface best practices
  • Learn about naming conventions in Fortran to avoid conflicts
  • Explore error handling and debugging techniques in NAG Fortran Compiler
  • Study examples of subroutine and module interactions in Fortran
Fortran programmers, software developers working with scientific computing, and anyone troubleshooting compilation issues in Fortran using NAG Fortran Compiler.
ASGtFT
I'm having problems compiling files with interfaces in Fortran. My compiler is NAG Fortran Compiler Release 5.2. I get this error:
Error: subroutines.f90, line 2: USE TEST_MOD in program-unit MY_SUB imports
symbol MY_SUB
detected at TEST_MOD@<end-of-statement
This happens when I try to compile this file, called 'subroutines.f90':
Code:
subroutine my_sub (a)
  use test_mod
  real a
  print *, a
end subroutine
The mod file 'test_mod' it refers to compiles correctly, and its code is here:
Code:
module test_mod interface
    real a
  end subroutine
end interface
end module
END
Am I using the correct code, or is something wrong here? Thanks!
I'm not really a Fortran programmer, but it seems like you're importing a subroutine called my_sub into another one of the same name. What exactly are you trying to do?
