Comparing Best-fits of different data sets that have different noise levels
This discussion focuses on comparing model fits for two data sets, day1 and day2, using the non-linear least squares method. The challenge arises from day1 containing significantly noisier data than day2, leading to an inherently larger RMS for day1. To achieve a fair comparison independent of noise levels, the discussion suggests employing a probability model that accounts for noise distribution. Additionally, utilizing the likelihood ratio test is recommended for a more robust comparison of the model fits.
  • Understanding of non-linear least squares fitting
  • Familiarity with RMS (Root Mean Square) error measurement
  • Knowledge of probability models and noise characterization
  • Experience with likelihood ratio tests in statistical analysis
  • Research methods for noise characterization in data sets
  • Learn about the implementation of likelihood ratio tests in model comparison
  • Explore advanced non-linear least squares fitting techniques
  • Investigate statistical methods for assessing model fit quality
Data scientists, statisticians, and researchers involved in model fitting and analysis of noisy data sets will benefit from this discussion.
zachzach
Suppose I have 2 sets of data: day1 and day2. I want to fit a model to both data sets and then compare them to each other to see which one fits the model the best (the fit is done with a computer using non-linear least squares method). The RMS of the fit would be fine except that day1 has much noisier data than day2 and the noise level is unknown. This makes the RMS of the fit for day1 (the noisy data) intrinsically larger than the RMS for day2 simply because of the noise. Is there anyway to compare the fits that is independent of the noise level?
I don't see how you can make a comparision unless you are willing to create a probability model for the data that includes the distribution of the noise. If you are willing to characterize the noise then you could consider a computation based on the "liklihood ratio test".
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 26 ·
9K
