Calculate Line Integral of Vector Field f(x,y) over Curve C | Homework Problem
The discussion revolves around calculating the line integral of a vector field f(x, y) over a specified curve C. The vector field is defined as f(x, y) = (x^2 + y^2) i, and the curve is parameterized by x = 2 + cos t and y = sin t for t in the range [0, 2π].
  • Participants discuss the representation of the vector field, questioning whether it should be expressed with only an i component. There are attempts to compute the integral and reflections on the results obtained, with some participants noting discrepancies in expected outcomes.
The discussion is active, with participants sharing their calculations and questioning the validity of the results. Some express uncertainty about the correctness of the problem statement or the potential for errors in the reference material being used.
There are indications that participants are self-studying and referencing specific textbooks, which may contain errors. The discussion highlights a lack of consensus on the expected result of the integral, with some participants arriving at zero while others mention a different expected value.
stratusfactio
calculate the integral f · dr for the given vector field f(x, y) and curve C:
f(x, y) = (x^2 + y^2) i; C : x = 2 + cos t, y = sin t, 0 ≤ t ≤ 2π (2pi)
Would the vector F simply be <(x^2+y^2),0> since there is no j component?
The solution is 4pi and I'm getting zero.
integral of C = F · dr
F = <((2+cos t)^2 + (sin t)^2),o> = <(5 + 4 cos t), 0>
dr = <-sin t, cos t>
Integral of C [0, 2pi] <(5 + 4 cos t), 0> · <-sin t, cos t> = 0 :(
I'm thinking that my error lies in the vector I'm using for F.
If the problem is exactly as you stated, then the correct answer is 0.
That's right, the F vector function only has a i component. It would be equivalent as writing it as F(x,y) = <x^2 + y^2, 0>
BTW I posted this same exact problem. :P where did you find this?
^Haha. I'm self teaching myself Multivariable Calculus using this online book: http://www.mecmath.net/calc3book.pdf in conjuction with Youtube's UCBerkely Multivariable Calc lectures.
It's just weird because I did all the steps and analyzed each step and can't see where I went wrong...we may be right because I see you got 0 too, sometimes the books make errors. I just don't see how we can get 4pi when we're evaluating an integral involving trig. when it's going to give us a rational number.
I was doing the same with that same book. :P There were a few other errors too in other parts. I think the book just needs more revising.
