How does light travel Through a vacuum
by Darrenmackenz
Tags: light, travel, vacuum
Darrenmackenz
Darrenmackenz is offline
#1
Jul26-11, 05:59 PM
P: 16
Hi Im new, Ive read the FAQ's and none of them seem to help.
Its a classic question I know but I cant seem to find a full answer.
I understand that light is part of the electromagnetic spectrum
I also understand that light acts as both a particle and a wave.
I think I understand the basics that, light as it travels through a vacuum oscillates between a magnetic field and a electric field at 90 degrees to each other.
How does this all, get a photon from point A to point B in a vacuum if there is no "ether" with which a photon can travel within?
Thanks
Phys.Org News Partner Physics news on Phys.org
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Mapping the road to quantum gravity
Chameleon crystals could enable active camouflage (w/ video)
LostConjugate
LostConjugate is offline
#2
Jul26-11, 06:20 PM
P: 842
A photon is only a change in the position of an electrostatic source. It is the electrostatic force that travels through the vacuum.
Drakkith
Drakkith is offline
#3
Jul26-11, 06:28 PM
PF Gold
Drakkith's Avatar
P: 11,057
Quote Quote by LostConjugate View Post
I think its an electromagnetic force, not an electrostatic. A photon has both electric and magnetic fields.
Darrenmackenz
#4
Jul27-11, 04:00 AM
P: 16
I'm going to need more information than that, how exactly does a photon or wave both move in a vacuum?
mikeph
mikeph is online now
#5
Jul27-11, 04:36 AM
P: 1,205
Quote Quote by Darrenmackenz View Post
Thanks
I don't know if it's a misunderstanding or a grammatical error, light doesn't travel between a magnetic field and electric field. Light is itself an oscillation of electric and magnetic fields. The oscillation propagates according to Maxwell's equations. And a vacuum means devoid of mass, not necessarily electromagnetic fields.
How do you define an ether and what gap in our understanding requires it?
Darrenmackenz
#6
Jul27-11, 04:52 AM
P: 16
It's a grammatical error sorry, I get that light itself oscillates between magnetic and electric. Maybe you could explain to me how the oscillation propergates according to maxwell.
I refered to an ether in the context of a medium in which light could travel through. Sound for example travels through air as it's medium. I understand that light does not need a medium in which to travel, I just don't fully understand why.
You say vacuum means devoid of mass which makes sense but not necessary electromagnetic fields, what would cause such a field in vacuum?
Thanks for helping me understand this.
mikeph
#7
Jul27-11, 05:22 AM
P: 1,205
If you combine Maxwell's equations for the case of no charge, the result is a wave equation, and one solution of that equation is an electromagnetic wave. It's difficult to convince a sceptical reader using only words and no equations, but it should be demonstrated in some popular textbooks (Griffiths for example should be in every physical sciences library).
Sound travels through air as it's medium- by this you mean, sound itself is a vibration in the air molecules, correct? A sound wave is fully characterised by the displacement of molecules from their equilibrium point. In the same way, a light wave is fully characterised by the displacement of the electric and magnetic fields from their equilibrium points.
Anything that couples to the electromagnetic field will create a field. Put a charge in empty space and it automatically comes with an electromagnetic field, not just where the charge is, but everywhere. It's the same as the gravitational field, and me asking you "how does the Earth orbit the sun? Why can the gravitational field cause the mutual interaction between a star and planet when there is a huge vacuum between them?" The vacuum simply means no matter is there. The fact that no matter is between two objects does not stop them from interacting.
DaleSpam
DaleSpam is offline
#8
Jul27-11, 05:44 AM
Mentor
P: 16,485
Thanks
Do you understand Maxwells equations, in particular Faraday's law of induction? Do you understand that Faraday's law works even in vacuum? I.e. Do you understand that vacuum does not act as a "shield" for electric and magnetic fields?
If you understand those then light going through vacuum is an unavoidable logical consequence.
Darrenmackenz
#9
Jul27-11, 05:51 AM
P: 16
Ok, air molecules who's equilibrium is being displaced is already present before a sound is even made.
Is there already an electromagnetic field present before light is even introduced?
If there isn't does light provide it's own field with which to travel?
harrylin
harrylin is offline
#10
Jul27-11, 05:53 AM
P: 3,178
Thanks
Hi Darren, welcome to Physicsforums.
There is no positive evidence that "there is no ether", and a photon in transit can be regarded as a kind of wave packet. Thus it's a concept that you can use. As a matter of fact, many famous physicists (incl. Einstein) concluded that vacuum cannot be nothingness, which implies some kind of ether.
However, there is no evidence of something like "ether particles", and as far as we can tell, no linear velocity wrt an ether can be established by measurements (it would even invalidate relativity theory). That may explain why many people conclude that there is no ether.
Best,
Harald
saim_
saim_ is offline
#11
Jul27-11, 05:54 AM
P: 134
The "medium" that your intuition might require is the electromagnetic field. Oscillation of air particles produces sound. Oscillation of EM field produces EM waves like light. Electromagnetic field is just as physical as the air around you.
HallsofIvy
HallsofIvy is offline
#12
Jul27-11, 05:59 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,900
Thanks
Why would a particle (photon) need to travel "within" anything? It is only when you think of light as a wave that you need something to "wave". "Vacuum" means there is no matter. There are still fields such the gravitational field and electromagnetic field at every point in space. A light wave is a "ripple" in the electromagnetic field.
Quote Quote by Drakkith View Post
No to both of these. A light wave is a ripple in the electromagnetic field. It does not "oscillate between a magnetic field and an electric field". At every point there is both a magnetic force vector and an electric force vector- at right angle to one another.
Darrenmackenz
#13
Jul27-11, 06:01 AM
P: 16
Quote Quote by DaleSpam View Post
I think I understand it, an electric field can be induced by a magnetic one moving at 90 degrees to it. The basics of a dynamo, and the opposite is the basics of a motor.
Right?
So your saying light induces it's own electric and magnetic fields by oscillating them, this then becomes self propergating.
mikeph
#14
Jul27-11, 06:02 AM
P: 1,205
Yes.
No. Light is just an oscillation in a pre-existing electromagnetic field.
Do sound waves create air particles? Do water waves generate water?
Darrenmackenz
#15
Jul27-11, 06:53 AM
P: 16
Quote Quote by MikeyW View Post
Yes.
Ok that all works in my head.
Here's another question, how did the pre existing field get where it is, i.e. the void in space? left over from the big bang?
jambaugh
jambaugh is offline
#16
Jul27-11, 07:23 AM
Sci Advisor
PF Gold
jambaugh's Avatar
P: 1,767
It is built into the structure of space. One can speculate about what lies deeper but for now it is sufficient to describe how the "vacuum" behaves and w.r.t. classical moving charges, that is what Maxwell's Equations describe.
Darrenmackenz
#17
Jul27-11, 07:33 AM
P: 16
Quote Quote by jambaugh View Post
Humour me, what's your speculation? I'm interested in what people think.
mikeph
#18
Jul27-11, 07:46 AM
P: 1,205
Electroweak interaction.
http://en.wikipedia.org/wiki/Electroweak_interaction
Register to reply
Related Discussions
Vacuum travel formula creation General Physics 4
How do waves travel in a vacuum? General Physics 4
Why Sound Doesnt Travel Through A Vacuum Introductory Physics Homework 3
How does light travel in a vacuum? Introductory Physics Homework 10
How does light travel in a vacuum?? Introductory Physics Homework 1
