What Wavelength of Light Dislodges an Electron from Sodium?
  • Thread starter Thread starter Edin_Dzeko
    Energy Wavelength
The discussion revolves around calculating the wavelength of light required to dislodge an electron from sodium using the photoelectric effect. Participants explore the conversion of energy from kJ/mol to J and subsequently to wavelength in nanometers (nm).
  • Homework-related
  • One participant states the energy required to dislodge an electron from sodium is 275 kJ/mol and seeks to find the corresponding wavelength of light.
  • Another participant suggests converting kJ to J and using Avogadro's number to find energy per atom, but expresses confusion about the calculations.
  • Several participants discuss the correct approach to using Avogadro's number, with one emphasizing the need to divide rather than multiply to find energy per photon.
  • There are multiple attempts to calculate the wavelength, with one participant noting they consistently arrive at an incorrect value.
  • Participants highlight the importance of sanity checks in calculations, questioning the reasonableness of large energy values obtained.
  • One participant finally reports achieving the correct wavelength of 435 nm after resolving computational errors.
Participants generally agree on the need to convert energy from kJ/mol to J and then to wavelength, but there is disagreement on the correct method of applying Avogadro's number and the calculations involved. The discussion includes multiple competing views on the approach to the problem, and it remains unresolved until one participant finds the correct answer.
Participants express uncertainty regarding the application of Avogadro's number and the dimensional analysis involved in the calculations. There are references to significant figures and the importance of careful computation throughout the discussion.
Edin_Dzeko
The energy required to dislodge electron from sodium and metal via the photoelectric effect is 275 kJ/mol. What wavelength in nm of light has sufficient energy per photon to dislodge an electron from the surface of sodium?
How do I convert 272 kJ/mol to J so that it cancels out Plank's Constant and the light leaving me with m which I can convert to nm?
I kept trying and failing. The book has the answer as 435 nm and unfortunately, it doesn't show the work. I'd like to know how it got the 435 nm.
Well, of course the kJ = 1000 J, the mole needs to be canceled out by how many atoms are in a mole. Use Avagadro's number for this.
Yeah I get how to convert the KJ -> J. But the mole is the problem. And I've tried avagdro's but the answer still doesn't match what's in the book. Where I am currently in the chapter, the book hasn't even introduced Avagadro's number yet so I wasn't sure if that's really what was needed but even after trying it out, I'm not getting the correct answer. Look:
275,000 x 6.022E10^23 / mole = 1.656E10^29 J/atom
(3.00x10E8 m/s)(6.626E10-34 j*s)
------------------------------------------ =/=435 nm (even after you convert m -> nm)
(1.656E1029 j)
I just don't get it
Whoa, think about what you're doing for a second. What are the units for Avagadro's number? Does 1.656x10^29 Joules of energy PER atom sound even vaguely reasonable? You're multiplying when you should be dividing.
But aren't you trying to get the moles to cancel out so therefore you set up the equation like this?:
....... 6.022E10^23
275E10^3 J/moles ------------------------
.......1 mole
moles cancels with moles and you multiple 275,000 to 6.022E10^23. That's what I've been doing this whole time.
In the back of my textbook Avagadro's number = 6.022E10^23/mol
This is actually very simple if you know what Avogadro's number is. It's the number of atoms (or molecules or ions or whatevers) in a mole. Now, if I told you that is costs $4 for a dozen cans of coke, how would you figure out the price per can? You would divide the total price by the number of cans in a dozen, right? So how do you get the energy per atom, if you know the energy per mole?
Edin_Dzeko said:
So what exactly I'm I doing wrong?
You're supposed to be calculating energy per photon. That means you take the amount of energy in a mole of photons and divide it by the number of photons in a mole of photons.
It's really important that you do sanity checks. Pengwuino asked, "Does 1.656x10^29 Joules of energy PER atom sound even vaguely reasonable?" THINK about that. 1.656x10^29 is a really BIG number. A photon is the smallest possible particle of light, so it should have a really SMALL energy. 2.2x10^18 is smaller than 1.656x10^29, but it's still way, way too big. You expect 10^-something for the energy. You should immediately realize, getting numbers like that, that something is wrong.
I really still don't get it. I re-did the math switching around the division of the avagadro's number. I put the 275000 in the calculator first and I got 4.566E10^-19. When I divide with the hc I'm getting 4.35 m and when I convert to nm I still get 4.35 nm and not 435
Well, at least now you're close. You've just got to find where you let the decimal point slip by a couple of places. Everyone makes those mistakes -- just go back and track it down.
Could you explain this remark?
How can you convert 4.35 m to nm and get 4.35? 4.35 m = 4,350,000,000 nm.
What is the numerical value of the product hc equal to when you do your calculation?
You're just a computation error away from the problem.
However, to answer your original question, Avagadros number is actually [itex]6.022x10^23 {{atoms}\over{mole}}[/itex]. It's the number of atoms in 1 mole of something. That's why your answer came out incorrectly and your dimensional analysis made no sense.
Remember, whenever you use a conversion, you need to know exactly what it means.
I really still don't get. Was just reading about it in the textbook and I still don't understand. The texbook has this:
"One mole of anything is 6.022E10^23 units of that thing."
Does that basically mean just divide?
Here's another thing, 1 mol = 6.0221421E10^23
So If I used that as a conversion factor to convert 275,000 J/mol to get the mol to cancel out, wouldn't I set it up like this:
......6.022E10^23
275,000 J/mol -------------------
.....1 mol
That's why I was multiplying in the first place. I really still don't get this. Why do I do it like this instead? :
275,000 J/mol
6.022E10^23/mol
The book seems like it's also teaching something else about converting between number of atoms and number of moles. Is the problem here that I'm not converting between moles and atoms in my particular problem but rather I just need to get the mol to cancel out? Is that why I have to divide?
Oh sorry. Problem solved. I finally got 435.348226 and due to significant figures it comes to 435 nm. I got the right answer this time around. Thanks.
9K
  • · Replies 35 ·
9K
