Plotting z^2-xy+1=0 with Mathematica - Interval around Origin
  • Context: Undergrad
  • Thread starter Thread starter heman
    Function Plotting
The discussion focuses on plotting the equation z^2 - xy + 1 = 0 using Mathematica. Users can rearrange the equation to z = sqrt(xy - 1) and utilize the Plot3D function for a 3D plot. The recommended commands include ContourPlot[z^2 - x*y + 1 == 0, {x, -1, 1}, {z, -1, 1}] for contour lines and RegionPlot[z^2 - x*y + 1 <= 0, {x, -1, 1}, {z, -1, 1}] for visualizing the solution set as a shaded region around the origin.
  • Familiarity with Mathematica syntax and functions
  • Understanding of quadratic equations in multiple variables
  • Basic knowledge of 3D plotting techniques
  • Experience with contour and region plotting methods
  • Explore advanced features of Mathematica's Plot3D function
  • Learn about the ContourPlot function in detail
  • Investigate the RegionPlot function for visualizing inequalities
  • Study the implications of quadratic equations in higher dimensions
Mathematics students, educators, and researchers interested in visualizing complex equations, as well as Mathematica users looking to enhance their plotting skills.
heman
hi,i want to know the command which i have to give to plot this using mathematica.actually interval should be sufficient and near by origin.thx in advance.
z^2-xy+1=0
First rearrange to get:
z = sqrt(xy - 1)
Then use something like
Plot3D[Sqrt[x y - 1],{x,1,10},{y,1,10}]
is a quadratic equation in two variables, z and x. In order to plot this equation, we can use the ContourPlot function in Mathematica. This function takes in an expression and plots the corresponding contour lines.
In this case, we can define the expression as z^2-xy+1 and use the ContourPlot function to plot it. The code for this would be:
This will produce a plot with the interval around the origin (-1,1) for both x and z variables. You can adjust the interval as per your requirement.
Additionally, you can also use the RegionPlot function to plot the solution set for this equation. The code for this would be:
This will produce a shaded region around the origin, indicating the solutions of the equation.
I hope this helps. Happy plotting!
