Variation of sea water temperature as a function of air, and solar intensity
The discussion centers on the variation of sea water temperature in relation to air temperature and solar intensity, exploring how these temperatures can differ significantly under various conditions. Participants examine both theoretical and observational aspects of temperature differences, particularly in extreme environments.
  • Some participants note that during the daytime, sea water can remain warmer than air due to its poor solar reflectivity, but there are instances where sea water is colder than air by 5-10 degrees Celsius or more.
  • It is suggested that the stability of water temperature is influenced by its large heat capacity, with exceptions in shallow waters, and that ocean currents can cause variations in sea temperature.
  • One participant mentions that in summer over the Arctic Sea shore, air temperatures can exceed 20 degrees Celsius while sea water remains just above 0 degrees Celsius, indicating a significant temperature difference.
  • Another participant speculates on the maximum temperature difference that could occur, citing extreme conditions such as winds from the continent over open sea, which could lead to large discrepancies in temperature readings.
  • Concerns are raised about the definition of 'air temperature' in varying measurement conditions, such as height above sea level or location on a ship.
  • A participant shares an anecdote about experiencing a temperature drop of 5 to 6 degrees Celsius when a ship enters the Gulf Stream, although there is uncertainty regarding the specifics of this phenomenon.
  • Another participant suggests that local sea temperature changes can be significant even over short distances, such as entering waters influenced by river runoff.
Participants express a range of views on the temperature differences between air and sea water, with no consensus on the maximum possible difference or specific conditions that lead to these variations. The discussion remains unresolved regarding the exact mechanisms and measurements involved.
Participants acknowledge limitations in their knowledge, such as not being meteorologists and the variability of temperature readings based on measurement conditions. There is also mention of the need for specific data sources for sea temperature.
chetanladha
Hi.
During daytime sea water having poor solar reflectivity remains warmer than the air.
But at times, water has also been found to be colder than air, with the difference being 5-10 degrees C.
Can anyone please justify how could that be possible?
Science news on Phys.org
Often even much more (like 20C). Water temperature is just pretty stable, due to its large heat capacity (except very shallow waters). Due to ocean currents sea temperature may be higher (e.g. Gulfstream at European coast) or colder (Canary stream at Western Africa coast) than average.
Air gets its temperature very quickly from the ground - and keeps it often even hundred miles from the shore as it is blowed by wind over the sea.
In a Summer over Arctic Sea shore you quite often may find air at above 20C and sea water just above 0C.
Thanks for your response.
So there could be a major difference in temperature between the two mediums, at the same time and same location.
Any guesses on what could be the maximum value of difference?
I don't know the Guiness book record - I'm not a meteorologist, but locally it must be really high. E.g. at Antarctica shore, or Siberian/Arctic Sea, if wind blows from the continent (at -50C or so) over open sea (just above 0C).
Or at Namibian shore, if the wind warmed to +50C over sunny desert goes over the sea cooled by Antarctic Benguela current to +15C or so.
Anyway - in such condition 'air temperature' is not well defined. You'll get much different results if you measure it 1m above the sea, at the deck of your large ship, or at top of its stem.
xts said:
I don't know the Guiness book record - I'm not a meteorologist.
Thanks again.
I am trying to plot temperature distribution in a ship for worst case climatic conditions..
This was really helpful..
I have heard that when a ship sailing in atlantic, enters gulf stream the temperature of sea water could drop by 5 to 6 C in an hour's journey or so.
Do u have information on any such conditions?
You may find (google them!) many services providing sea temperature data (e.g. US Navy).
I don't know about entering Gulfstream, what you quotes seems reasonable (regarding that temp raises, not drops, as you enter it), but even if you sail small fishing boat along the shore the water temperature may change by 10C or so on few hundred yards - e.g. as you enter waters brought by some river (that's a case of e.g. northern Norwegian shore during Spring - the ocean has 15C or so, warmed by Gulfstream, while water at fjords and fjord mouths has below 5C, as is supplied by melting snow).
  • · Replies 16 ·
11K
  • · Replies 42 ·
9K
  • · Replies 152 ·
12K
