How much time does it take until the pulses pass each other?
  • Thread starter Thread starter rocky811
    Time
The discussion focuses on calculating the time it takes for two transverse wave pulses to pass each other in parallel wires. Wire A has a tension of 2980 N and a wave velocity of 377.603 m/s, while Wire B has a tension of 321 N and a wave velocity of 123.93 m/s. The solution involves equating the positions of the two waves using the formula v1t = L - v2t, where L is the length of the wires (61.3 m). The final step is to solve for time (t).
  • Understanding of wave mechanics and transverse waves
  • Familiarity with tension and mass per unit length calculations
  • Knowledge of basic algebra for solving equations
  • Ability to apply the wave velocity formula: v = sqrt(Tension/mass per length)
  • Study the derivation of wave velocity in different mediums
  • Learn about wave interference and superposition principles
  • Explore the effects of varying tension on wave speed in strings
  • Investigate real-world applications of wave propagation in engineering
Physics students, engineering students, and anyone interested in wave mechanics and their applications in real-world scenarios.
rocky811
Here's the problem I need some help with!
Two wires are parallel, and one is directly above the other. Each has a length of 61.3 m and a mass per unit length of 0.0209 kg/m. However, the tension in wire A is 29.8 x 10^2 N, while the tension in wire B is 3.21 x 10^2 N. Transverse wave pulses are generated simultaneously, one at the left end of wire A and one at the right end of wire B. The pulses travel toward each other. How much time does it take until the pulses pass each other?
I know how to find the velocity of each wave:
v= sqrt (Tension/mass per length)
vA=sqrt (2980/.0209)=377.603 m/s
vB= sqrt (321/.0209)= 123.93 m/s
I just don't know where to go from here. Thanks!
You did the hard part! Just write the position of the two waves and equate them:
[tex]v_1 t = L - v_2 t[/tex]
and solve for t.
Thank you! I guess I just thought it would be harder than that to figure out the time so I don't know what I was thinking. But thanks!
