Is y a function of x or Sine in f(x)=sinx?
  • Thread starter Thread starter roger
    Sine
The discussion clarifies that for the function f(x) = sin(x), y is a function of both x and sin(x). The term af(x) indicates that the output of f(x) is multiplied by a constant a, while f(ax) signifies that the input x is scaled by a before applying the function f. Both transformations affect the graph of sin(x) differently, with af(x) altering the amplitude and f(ax) modifying the frequency. The original points on the x-axis remain unchanged for both transformations.
  • Understanding of basic function notation and terminology.
  • Familiarity with trigonometric functions, specifically sine.
  • Knowledge of function transformations, including amplitude and frequency adjustments.
  • Basic graphing skills to visualize function changes.
  • Research function transformations in detail, focusing on amplitude and frequency changes.
  • Learn about the properties of trigonometric functions, particularly sine and cosine.
  • Explore the implications of scaling inputs and outputs in functions.
  • Study graphical representations of transformations to better understand their effects on functions.
Students of mathematics, educators teaching trigonometry, and anyone interested in understanding function behavior and transformations in calculus.
roger
Hello.
Please can someone help me with this :
f(x)=sinx
For the above, is y a function of x OR is y a function of Sine ?
Secondly, I don't understand what it means by :
a f(x)
and f(ax)
where a is 2.
What I need to know is what does each do to the graph of sin x ?
Also do each of the two af(x) and f(ax) pass the same points on the x-axis as just sinx ?
Please help me
rog
For f(x) = sin(x), f is a function of x.
What is meant by af(x) is that the value of f(x) is multiplied by the constant a. The expression f(ax) means that x is multiplied by the constant a, and then function f is applied to that value.
Hope that helps! :)
f(x)=sin(x) is also a function of sin(x).
It depends how you look at it.
If you take y=sin(x), then f(x)=y. So f is clearly a function of y=sin(x).
However, since sin(x) is a function of x, f is also a function of x.
If f were given by: f(x)=sin(x)+x, it would not be a function of sin(x), but only of x.
  • · Replies 26 ·
