Charging an electrochemical capacitor
The discussion centers on the charging behavior of symmetrical electrochemical capacitors. When charged to 1V, one electrode reaches a potential of +0.5V while the other reaches -0.5V, resulting in opposite voltage measurements across the electrodes. The 0V reference point occurs when the system is at equilibrium, indicating no current flow after discharge. This understanding is crucial for effectively testing and utilizing electrochemical capacitors in various applications.
  • Understanding of electrochemical capacitor fundamentals
  • Knowledge of electrode potential and voltage measurement techniques
  • Familiarity with constant current charge-discharge testing methods
  • Basic principles of electrical equilibrium in capacitor systems
  • Research the principles of symmetrical electrochemical capacitor design
  • Learn about measuring electrode potential using voltmeters
  • Explore constant current charge-discharge protocols for capacitors
  • Investigate the effects of equilibrium on capacitor performance
Electrical engineers, researchers in energy storage technologies, and anyone involved in the design and testing of electrochemical capacitors will benefit from this discussion.
nubie43
I have a very basic question confusing me about charging electrochemical capacitors -
When you charge a symmetrical electrochemical capacitor to 1V, because one electrode becomes positively charged and the other negatively charged, the electrode potential across one will be +0.5V, and the electrode potential across the other will be -0.5V?
So if you were to measure the CV across each electrode they would both start at 0V, and travel in opposite directions to + and - 0.5V?
You mention a 0v point. Do you have an explanation at which point in the capacitor exactly where this is?
Im not really sure about that either. When testing a cell for example by constant current charge discharge, you apply the current, and the voltage will increases to your set limit from 0V then, goes back on discharge.
I suppose 0V would be when the system is at equilibrium, where no current flows after you discharge the device?
  • · Replies 30 ·
  • · Replies 19 ·
  • · Replies 27 ·
