What Is the Gauge Pressure at the Inlet of a Pipe in a Bourbon Distillery?
The discussion revolves around determining the gauge pressure at the inlet of a pipe in a bourbon distillery, where a mixture of ethanol and water is being pumped. The problem involves fluid dynamics concepts, particularly Bernoulli's equation and flow rates, as the product is transferred through a plumbing system with varying pipe diameters and elevations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss calculating the outlet speed of the product based on the volume of an aluminum cylinder filled over a specific time. There are questions about the necessary formulas, including Bernoulli's equation and the relationship between flow rate, area, and speed. Some participants express uncertainty about how to proceed with calculating gauge pressure without first determining outlet speed.
Several participants have provided guidance on the application of Bernoulli's equation and the relationship between flow rate and speed. There is ongoing exploration of the definitions and calculations needed to find absolute pressure and gauge pressure. Multiple interpretations of the problem setup are being discussed, particularly regarding the height reference point for the pipe.
Participants are working with specific measurements and assumptions about the fluid's properties, including density. There is some confusion regarding the atmospheric pressure value and its relevance to gauge pressure calculations.
Tycho
In a bourbon distillery plant, the refined product, approximated as 40% by weight ethanol, 60% by weight water, is pumped through a plumbing system. At the OUTLET, where the inner diameter of the pipe is 5.08cm, the product fills an aluminum open cylinder (Diameter .442m, height 1.26m) in 98.9 seconds. At the inlet of this pipe the diameter is 7.62 cm and the pipe is 3.85m above the cylinder. the density of the product is 922kg/m^3
a) what is the outlet speed of the product?
b) what is the gauge pressure at the inlet of the pipe (diameter 7.62cm)
WHEW! okay, question a...
the outlet speed: it fills an aluminum open cylinder in 98.9 seconds. first step, find the volume of the cylinder? the volume of a cylinder is given by: pi*R^2*length, right? so: pi(.221^2)1.26m = .19m? my units are wrong, and the volume seems AWFULLY small.
lets roll with it, though...
it fills this volume in 98.9 seconds. (1.65 mins). Now, I have the volume filled, and the time it took. (should be .019L/1.65min) how do i get this into useable figures (like L/min)?
now for question b:
the gauge pressure...
it wants the gauge pressure at the inlet of the pipe. (diameter 7.62cm)
I can't do this until i get the outlet speed, correct? even if i had the outlet speed, I'm not sure how to obtain the gauge pressure?
i know this is really long and laborious... but I've been working pretty hard on this, and any help would be appreciated. thank you all.
You have to use Bernoulli's Equation
And also this one : Volume Flow Rate = Area * Flow Speed ( Q = AV )
also Gauge Pressure = Abosolute Pressure - Atmospheric Pressure
at open surfaces gauge pressure = 0
Bernoulli's eqn
okay, i started to write it out, but with all the subscripts and superscripts, it was looking NARSTY!
Any way you could start me out on it? I'm still drawing a blank.
btw, thanks for ALL of your assistance. you've been really nice and extremely helpful :smile:
3.85 m above of what?
from the top of the cylinder or from the bottom ...?
u have the figure right?
It says it is 3.85m ABOVE the cylinder
tycho brache, check pm
sorry for not reading ur question carefully :)
Volume of Cylinder / Time = Volume flow rate(Q)
Q = AV
A = outlet cross sectional area of the pipe
V = the outlet speed of the product
--------that's part a ---------
thanks! I was missing Q. that solved THAT problem!
okay so gauge pressure is absolute pressure - atmospheric pressure. since atmospheric pressure should be approximately = to 1, then it is absolute pressure -1? how do you find absolute pressure?
whu says atmospheric pressure == 1?
it is 101325 Pa
and for this problem u don't even need to think abt atmospheric pressure
at the atmosphere level the gauge presure will read zero
lol okay, so what next? gauge pressure will = absolute pressure?
what is the absolute pressure?
inlet
\outlet
apply bernoulli's eqn at inlet and outlet
10K
29K
