Power series method and various techniques
The discussion focuses on solving first-order differential equations using power series methods, specifically addressing the equation y' = -(x^2) + 2/x + 3. While power series are typically reserved for second-order differential equations, participants suggest representing y as a power series in sigma notation, y = ∑(n=0 to ∞) a_n x^n, and differentiating to find y'. The right-hand side can be expressed as a power series using the generalized binomial theorem, allowing for coefficient comparison to derive solutions. This approach results in a unique equation for each coefficient a_n, excluding a_0, which represents the constant of integration.
  • Understanding of first-order differential equations
  • Familiarity with power series and sigma notation
  • Knowledge of the generalized binomial theorem
  • Ability to manipulate and compare coefficients in series
  • Study the application of power series in solving second-order differential equations
  • Learn about the generalized binomial theorem and its applications in series expansion
  • Explore techniques for integrating first-order differential equations directly
  • Investigate the convergence of power series and their radius of convergence
Mathematicians, engineering students, and anyone interested in advanced techniques for solving differential equations using power series methods.
Jen_Jer_888
I know how to do problems like y' + y = 0 where you can replace y' and y with a series in sigma notation, manipulate and compare coefficients.
But how do you solve a differential by power series that does not also include y or a higher order derivative? For example, y' = -(x^2) + 2/x + 3. What power series techniques can be employed here?
Any help would be appreciated!
You not normally use a power series solution for first order differential equations, they're normally for second order and above. In your example you can integrate straight away to find your solution.
If you must use a power series then write
[tex]y= \sum_{n= 0}^\infty a_nx^n[/tex]
so that
[tex]y'= \sum_{n= 1}^\infty na_nx^{n-1}[/tex]
Write the right hand side as a power series in x (in your example, [itex]-x^2+ 2/x+ 3[/itex], write 2/x as a power series using the generalized binomial theorem) and compare coefficients of the same power. The only difference is that now, you will have a single equation for each "n" rather than a recursion relation.
Of course, there will be no equation involving [itex]a_0[/itex]- that's your constant of integration.
  • · Replies 24 ·
  • · Replies 27 ·
16K
