How the coating of steel wool affects its rusting rate
The discussion revolves around a science experiment investigating how the coating of steel wool influences its rusting rate, focusing on the chemical reactions involved in rust formation and the role of different materials in the process.
  • Exploratory, Conceptual clarification, Chemical reasoning
  • Participants explore the electrochemical processes of corrosion, questioning the roles of anodes, cathodes, and electrolytes. There are attempts to clarify the concept of sacrificial anodes and the implications of using zinc or magnesium in the experiment. Some participants seek to confirm their understanding of reducing agents and the activity series of metals.
The discussion is active, with participants offering insights into the chemical principles at play and seeking clarification on specific concepts. There is a mix of understanding and uncertainty, particularly regarding the definitions and roles of various components in the rusting process.
Participants note potential gaps in background knowledge, such as familiarity with high school chemistry concepts, and question the relevance of electrolytes in the context of galvanized steel wool.
jisell9036
I'm doing a science experiment on how the coating of steel wool affects its rusting rate. I'm doing the background information right now. What I need help with is how to make sense of the chemical reaction of rust. Can someone give me examples of these things so it makes sense??
Corrosion is an electrochemical process that involves an anode, an electrolyte and a cathode. An anode is a piece of metal that readily gives up electrons. An electrolyte is a liquid that helps electrons move, and a cathode is a piece of metal that readily accepts electrons. When a piece of metal corrodes, the electrolyte helps provide oxygen to the anode. As oxygen combines with the metal, electrons are set free. When they flow through the electrolyte to the cathode, the anode metal disappears, being converted into rust.
I'm a little rusty on my high school chemistry, but I think the zinc(or magnesium?) acts as a sacrificial anode and cathodically protects the iron.
So instead of the oxidation reaction being
Fe -> Fe3+ + 3e-
it is
Zn -> Zn2+ + 2e-
because Zinc is a stronger reducing agent.
I probably have some of that information backwards, but that's the idea at least. What grade science or chem is this project for? Have you taken electrochemistry or any oxidation/reduction before?
ek:
are you talking about when you say a stronger reducing agent, that Zinc is higher on the activity list than Fe? So it will take the place of the iron. And could you explain how the electrolytes work in this equation?
Learning Curve said:
ek:
Zinc is lower on the list of Standard Reduction Potentials of Half-Cells. This means it is a stronger reducing agent, weaker oxidizing agent and will be more readily oxidized than iron, thus making it a sacrificial anode.
If you have Acrobat Reader, you can get the full table on the LAST page of this document:
http://www.bced.gov.bc.ca/exams/pdfs/0406ch_P.pdf
Electrolyte: Conducting liquid in an electrochemical or electrolytic cell.
I don't think electrolytes have any bearing on galvanized steel wool.
35K
  • · Replies 32 ·
