Calculating Rotor Revolutions for Space Probe Orientation Change
  • Thread starter Thread starter GingerBread27
    Revolutions Rotor
The discussion revolves around calculating the number of revolutions required by a rotor in an electric motor to change the orientation of a space probe by 30 degrees. The problem involves concepts of rotational inertia and conservation of angular momentum.
  • Exploratory, Assumption checking
  • The original poster attempts to apply the conservation of angular momentum but expresses uncertainty about how to begin the calculations. Some participants suggest a formula involving the moment of inertia, while others engage in informal exchanges about homework assistance.
The discussion includes various interpretations of the problem and informal confirmations of a solution, but there is no explicit consensus on the correct approach or final answer. Some participants appear to share methods that have worked for them in the past.
There is a mention of homework rules and informal offers of assistance outside the forum, indicating a collaborative environment among participants.
GingerBread27
The rotor of an electric motor has rotational inertia I am = 2.5*10-3 kg · m2 about its central axis. The motor is used to change the orientation of the space probe in which it is mounted. The motor axis is mounted along the central axis of the probe. The probe has rotational inertia Ip = 8 kg · m2 about this axis. Calculate the number of revolutions of the rotor required to turn the probe through 30° about its axis.
Not sure where to start, except that you have to use the idea of conservation of angular momentum.
(Ip*(degrees/360))/Im I am telling you, if you just send me an instant message, we've done the uf homework, you can get help from me on there... or just keep posting here... whatevers easier i guess
so it did work? that why you deleted your post?
its 266.67, and it does work, its worked for every uf student I've shown that to
yeah it worked lol
heh, good, i was wondering there for a minute...
  • · Replies 30 ·
