Minimum Speed for Hoop to Roll Without Slipping Around a Loop
The minimum speed required for a thin hoop of mass m and radius R to roll without slipping around a loop of radius r is √(gr). This conclusion is derived using the conservation of energy principle, where the potential energy at the top of the loop (mgr) is equated to the total kinetic energy (mv²) of the hoop. The analysis confirms that the minimum speed is independent of the hoop's mass and radius, relying solely on the loop's radius and gravitational acceleration g.
  • Understanding of conservation of energy in physics
  • Knowledge of centripetal acceleration and its formula
  • Familiarity with kinetic energy equations for translational and rotational motion
  • Basic concepts of rolling motion and the relationship between linear and angular velocity
  • Study the principles of conservation of energy in mechanical systems
  • Learn about centripetal force and its applications in circular motion
  • Explore the moment of inertia for different shapes and its impact on rotational dynamics
  • Investigate the effects of friction in rolling motion and conditions for rolling without slipping
Students and professionals in physics, mechanical engineering, and anyone interested in understanding dynamics of rolling objects and energy conservation principles.
physicsss
A thin hoop of mass m and radius R is rolling without slipping along a horizontal track. It then encounters a loop of radius r. If the hoop travels fast enough along the horizontal portion of the track it is able to go around the loop without losing contact with it at the top. Find the minimum speed the hoop needs to have on the horizontal portion of the track to accomplish this. Express in terms of m, R, r, and g.
What exactly have you tried so far?
Meanwhile, here's a couple of hints:
(1) Energy is conserved.
(2) Centripetal acceleration is speed squared divided by radius of circular path.
To find the minimum speed needed for the hoop to successfully go around the loop without losing contact, we can use the conservation of energy principle. At the top of the loop, the hoop will have both translational and rotational kinetic energy, as well as potential energy due to its height.
First, we can find the potential energy at the top of the loop by considering the height of the hoop above the ground. Since the hoop is rolling without slipping, the height of the hoop at the top of the loop will be equal to the radius of the loop, r. Therefore, the potential energy at the top of the loop is given by mgh = mgr.
Next, we can find the kinetic energy of the hoop at the top of the loop. Since the hoop is rolling without slipping, its translational kinetic energy is given by 1/2mv^2, where v is the speed of the hoop. Additionally, the hoop will also have rotational kinetic energy given by 1/2Iω^2, where I is the moment of inertia of the hoop (for a thin hoop, I = mr^2) and ω is the angular velocity of the hoop. Since the hoop is rolling without slipping, the linear speed of the hoop is equal to its angular speed, v = ωr. Therefore, the total kinetic energy at the top of the loop is given by 1/2mv^2 + 1/2Iω^2 = 1/2mv^2 + 1/2mr^2ω^2 = 1/2mv^2 + 1/2mr^2(v/r)^2 = 1/2mv^2 + 1/2mv^2 = mv^2.
Using the conservation of energy principle, we can equate the potential energy at the top of the loop to the kinetic energy at the top of the loop, and solve for the minimum speed v needed for the hoop to successfully go around the loop without losing contact:
mgr = mv^2
Solving for v, we get:
v = √(gr)
Therefore, the minimum speed the hoop needs to have on the horizontal portion of the track to successfully go around the loop without losing contact is √(gr). This speed is independent of the mass and radius of the hoop, and only depends on the radius of the loop and the acceleration due to gravity, g.
  • · Replies 42 ·
  • · Replies 60 ·
  • · Replies 21 ·
  • · Replies 18 ·
