What's Wrong with My Concrete Density Calculation?
  • Thread starter Thread starter chattkis3
The discussion revolves around a problem involving the calculation of the density of a chunk of concrete with a hollow spherical cavity. The original poster presents a formula to find the density based on the mass and volume of the concrete, but expresses confusion over the results obtained.
  • Participants discuss the formula for density, questioning whether the correct volumes are being used in the calculations. There is mention of negative results and discrepancies in the expected answer, prompting further examination of the setup and assumptions.
Some participants have offered guidance on the formula used, while others have pointed out potential errors in the application of the equation. There is a recognition of differing answers and calculations, with suggestions to consider significant figures and rounding in the context of the problem.
There is mention of a computer program's response to the calculations, indicating that the professor may have altered settings related to significant figures, which could be affecting the results.
chattkis3
Been working on this for hours!
Ive honestly given this problem 3 or more hours to no avail.
"An irregularly shaped chunk of concrete has a hollow spherical cavity inside. The mass of the chunk is 38 kg, and the volume enclosed by the outside surface of the chunk is 0.025 m3. What is the radius of the spherical cavity?"
This is what I have set up which is not working:
density of concrete = M / (Voutside surface - Vcavity)
what's wrong with that?? thankkks!
shouldn't it be?
[tex]\rho_{concrete} = \frac{M}{V_{outside}-V_{cavity}}[/tex]
What makes you think it's wrong?
Im getting a negative number if I do M / (Voutside + Vsphere) ... and the value I get (using a density for concrete of 2200) is .12m And the computer program is telling me that is wrong. I feel like I am missing something??
I get a different answer. Check you calculations. Remember that
[tex]V_{sphere}=\frac{4\pi r^{3}}{3}[/tex]
I don't think you're missing anything. Your original method is correct; your answer seems correct also.
Sirus, did you use my original equation with Voutside - Vcavity or Voutside + Vcavity
Ah, that's why! Yes, I used Cyclovenom's equation with a plus sign, which I think is incorrect. I think Doc Al is right. Try entering the answer with various precisions (round to a different number of decimals) and see if the program accepts your answer.
WOW, thanks for that. Let's just say I want a couple hours of my life back. The program is not suppose to be set up to worry about sig figs. But apparently my professor changed that option? **annoyed** thanks for the advice though everyone.
Oh sorry, actually it was suppossed to be a minus, the question on the top was just because i was :confused: because it wasn't working.
