Continuity Equation and the Bernoulli's Equation
The discussion focuses on the application of the Continuity Equation and Bernoulli's Equation in explaining fluid dynamics, particularly in the context of jet engines and garden hoses. The Continuity Equation, represented as A1v1=A2v2, illustrates the inverse relationship between cross-sectional area and fluid velocity. Bernoulli's Equation, P1 + pgy1 + 1/2pv1 = P2 + pgy2 + 1/2pv2, describes the relationship between pressure, height, and velocity in a fluid system. The conversation emphasizes the importance of understanding these equations to solve practical problems related to fluid flow and thrust generation in aviation.
  • Understanding of the Continuity Equation (A1v1=A2v2)
  • Familiarity with Bernoulli's Equation (P1 + pgy1 + 1/2pv1 = P2 + pgy2 + 1/2pv2)
  • Basic knowledge of fluid dynamics principles
  • Concepts of Newton's Three Laws of Motion
  • Explore the derivation and applications of Bernoulli's Equation in various fluid systems
  • Investigate real-world examples of the Continuity Equation in engineering and aerodynamics
  • Study the relationship between pressure and velocity in fluid dynamics
  • Learn about the design and functioning of jet engines, focusing on thrust generation
Students and professionals in physics, engineering, and aviation who seek to deepen their understanding of fluid dynamics and its practical applications in real-world scenarios.
Loneliheart
Skill Level II Problem
Use the Continuity equation to explain how jet engines provide a forward thrust for an airplane.
Skill Level Problem III
The Contintuity Equation is related to a powerful equation from fluid dynamics called Bernoulli's Equation. Do the research and answer the questions listed below.
  • Do research necessary to find Bernoulli's Equation (DONE)
  • Identify what each term in Bernoulli's Equation represents. (DONE)
  • Reread the problem given in Skill Level I of this thought Project. What assumption is built into the wording of the problem that becomes unnecessary if you use Bernoulli's?
  • Discuss how the Continuity Equation and Bernoulli's Equation might relate to one another.
Skill Level I Problem
One evening, a husband and wife are working in their garden. While watering the grass, the wife holds the hose horizontally and the water flows from the end of the hose. She twists the nozzle of the hose to partially close it and suddenly the water shoots farther from the end of the hose. This seems odd to her husband, who wonders, "Why does the stream of the water travel farther, since it appears that less water is flowing from the end of the hose?"
Your challenge is to give a scientific explanation for this seemingly unnatural phenomenon.
The Continuity Equation according to my textbook, A1v1=A2v2 A1 and A2 are the cross-sectional areas at points 1 and 2 v1 and v2 are the velocity of the fluid at point 1 and 2.
The Bernoulli's Equation according to my textbook, P1+pgy1+1/2pv1=P2+pgy2+1/2pv2
I understand P1 and P2 are the pressures on the fluid at points 1 and 2
p is the density of the fliud
g is the acceleration due to gravity, 9.8m/s sq.
y1 and y2 are the respective heights of the pipe at points 1 and 2
v1 and v2 are the velocities of the fluid at points 1 and 2.
In regard to Skill Level I: With my written expression learning disability problem, I have a hard time in math, only when answers to the question are essay style. In truth, we are learning how to use George Polya Four-Step Process to solve problems.
Understand the Problem
"Why does the stream of the water travel farther, since it appears that less water is flowing from the end of the hose?" Draw a picture to help visualize.
Devise a Plan
Discuss possible problem solving strategies for solving this problem. Which strategy (physical experimentation, information research, or mathematics) would be most likely to generate a successful solution? Why? Why do you think that the strategies that you eliminated would not be viable problem solving options for this situation?​
Carry out the Plan
Does the introduction of the Continuity Equation modify your interpretation of the original problem, or your strategy for solving it? If so how?
The equation give to use was A1v1=A2v2 A1 and A2 are the cross-sectional areas at points 1 and 2 v1 and v2 are the velocity of the fluid at point 1 and 2.
Choose some real numbers and show how this equation provides an answer to the husband's apparent problem.
I used made up numbers like 2 meter for A1, 1 meter for A2, and 10m/s for v1 and we solved for v2. therefore v2 is 20m/s.​
What does this equation suggest about the relationship between velocity and area?
Write out a detailed explanation of your solution to this thought project. Suggest some other situations in which Continuity Equation would come into play.​
Look Back
We had nothing in regards to look back.
In regards to Skill Level II: I found this information in my research trying to do this on my own but I still not sure how to answer anything correctly. I print a copy of this article on Jet engines from About.com Inventors. Which I will turn in with my assignments that are due Monday. http://inventors.about.com/library/inventors/blhowajetengineworks.htm".
I also found this follow information which might be of help to explain but I not sure of the right words. I have a hard time putting thing into my own words. Or, I have no one to talk to and hear me out and state if I am right and should right that down.
Identify Examples of Newton’s Three Laws of Motion.
NEWTON’S FIRST LAW – THE LAW OF EQUILIBRIUM
○ An airplane in straight and level flight at a constant velocity is acted upon by four forces: thrust, drag, lift and weight
○ When thrust is equal to drag, and lift is equal to weight, the airplane is in equilibrium
NEWTON’S SECOND LAW – THE LAW OF ACCELERATION
○ When an airplane’s thrust is greater than its drag (in level flight), the excess thrust will accelerate the airplane until drag increases equal to thrust
NEWTON’S THIRD LAW – THE LAW OF INTERACTION
○ The thrust from a jet engine consists of hot gases exhausted rearward producing a thrust acting forward
Describe the relationship between airflow velocity and cross-sectional area within a streamtube using the continuity equation.
• Velocity and area in a streamtube are inversely related
• The Continuity Equation: A1V1 = A2V2
• Mass flow is equal to the density times the area time the volume
• Mass flow = (rho)AV
• The density times the volume times the area are equal to the same for each cross section of the streamtube.
• (rho)1A1V1 = (rho)2A2V2​
Describe the relationship between total pressure, static pressure, and dynamic pressure within a streamtube using Bernoulli’s equation.
• Total pressure (PT), also called head pressure (HT), is the sum of static and dynamic pressure
• Static pressure (PS) is a measure of potential energy per unit volume
• Dynamic pressure (q) is the pressure of a fluid resulting from its motion, and is equal to 1/2(rho)V*2
• Equation is PT = PS + q
• Static pressure and dynamic pressure are inversely related
Marine Gouge. Aerodynamics 1. MediaWiki. 28 January 2011
<http://marinegouge.com/mediawiki-1.13.3/?title=Aerodynamics_1>
Date Access: July 31, 2011
I post help in the wrong area my second night on this forum. And now it will be too late for anyone to help. My assignment in due Monday night. August 2, 2011 I know it is against the rules but I need help more than a normal person for I suffer from a Written Expression Learning Disability.
Your deadline is way past and nothing I can say can benefit you at this point. I will post my remarks and comments for the benefit of future visitors to this thread. The comments are my views only.
First, it is not clear what you are asking us to do. You present your thoughts and leave it at that. Do you expect to pinpoint and correct errors? Do you expect us to say whether you got it right? Do you expect us to comment on whether you have provided a sufficient answer?
Second, yes it is against the rules to provide direct answers. Our role is to guide your thinking processes through the path to the answer. We do so posting written expressions that might include figures and diagrams. This is our only mode of communication. If you have a learning disability regarding written expression, Physics Forums may not be the best venue for you to seek help. We understand that you need more help than a "normal" person, but you have to understand that giving away answers is no help.
Third, my assessment is that you did your research, you put down what you found as best as you could and now you expect us that to pull it together for you. We will not do, that but we can provide a series of questions for you to answer that eventually will bring everything together. However, that requires time, a lot of time considering your disabiltiy. You posted your question on July 31, 2011 and expected an answer two days later. That is not enough time. If there were more time, someone could have prompted you to answer your own unanswered question, "What does this equation suggest about the relationship between velocity and area?" Even though you did a calculation and found that when the area is reduced the velocity increases, you did not make the connection to the hose. When the nozzle is twisted the water has higher speed and therefore shoots farther out than before.
In short, had you posted this early enough, I believe that we could have helped you in a way that would have accommodated your disability without compromising our guidelines.
  • · Replies 16 ·
10K
  • · Replies 16 ·
