| New Reply |
I was always told that EM radiation is a far field effect. Does this |
Share Thread | Thread Tools |
| Aug1-11, 04:55 AM | #1 |
I was always told that EM radiation is a far field effect. Does this mean that the light emitted from the accelerating electron is not right next to the electron but a little further out.
And also how do you calculate the frequency of the light coming off. When I looked through Griffiths it just seemed to talk about the total power radiated. |
| Aug1-11, 10:26 AM | #2 |
The bottom line it that there isn't less going on in the near-field compared to the far-field, there is actually more going on. Also, causality still applies: em energy must pass through the near-field to get to the far-field. It can't just appear. |
| Aug1-11, 11:33 AM | #3 |
Detecting frequency of an em radiation can be achieved by exposing it to an appropriate antenna and performing Fourier analysis of the induced electrical signal. Light is very small in wavelength thus it is not that easy to implement an appropriate 'antenna' to interact with visible spectrum. Even if optical antennas emerge and becomes practical, there is computing issue problem because it will require very fast processors to analyze PHz data stream and make real-time analysis. Considering a duty cycle ; frequency is not related to power in classical electromagnetics. |
| Aug1-11, 06:23 PM | #4 |
ok thanks for your answers, So far-field is where there is only the em radiation and no static fields. And when light is emitted from the electron is it always emitted next to the electron and then propagates out. Why can't it be emitted further out from the electron from its field energy.
| Aug2-11, 10:09 AM | #5 |
Because of causality. If a cause happens at one point in space-time that creates an effect in another point in space-time, then information must have traveled between those two points.
| Aug2-11, 06:49 PM | #6 |
I see good point .
| Aug3-11, 05:31 AM | #7 |
One questions regarding the frequency of emission... an electron oscillating at 10 MHz emits 10 MHz radiation - but it's not necessarily an oscillation that causes radiation, just an acceleration of charge. So what will the frequency of radiation be if we just accelerate it at, say 10 m s^-1? Some weird spectrum?
| Aug3-11, 01:54 PM | #8 |
| New Reply |
| Thread Tools | |
Similar Threads for: I was always told that EM radiation is a far field effect. Does this
| Radiation protection/ effects of radiation | Nuclear Engineering | 15 | ||
| Estimation of diffuse and direct radiation starting from the global radiation | General Physics | 1 | ||
| Heat is electromagnetic radiation OR heat is __spread by__ electromagnetic radiation? | Classical Physics | 2 | ||
| Emitted radiation and absorbed solar radiation | Astrophysics | 1 | ||
| EM radiation and Nuclear Radiation | Classical Physics | 6 | ||
