What is the Maximum Gravitational Force Between Two Uniform Spheres?
  • Thread starter Thread starter paprika
The problem involves calculating the maximum gravitational force between two uniform spheres, specifically a bowling ball and a billiard ball, using Newton's law of universal gravitation. Participants are exploring the implications of the gravitational force being equal and the conditions under which this force is maximized.
  • Participants discuss the nature of gravitational force and its dependence on mass and distance. There is an exploration of what conditions would maximize this force, particularly focusing on the distance between the centers of the spheres.
Some participants have offered insights into the relationship between distance and gravitational force, suggesting that the maximum force occurs when the spheres are in contact. Others are still seeking clarification on the implications of equal force exerted by both spheres and how to approach the problem conceptually.
There is an emphasis on understanding the gravitational interaction without altering the masses, and participants are questioning the setup and definitions related to the problem's conditions.
paprika
The problem is as follows:
A bowling ball (mass = 7.2kg, radius = 0.11 m) and a billiard ball (mass = 0.39 kg, radius = 0.028 m) may be treated as uniform spheres. What is the magnitude of the maximum gravitational force that each can exert on the other.
I already asked my physics teacher for help, sat with the man for like 10 minutes after shool but he still couldn't help me under stand why the answer to the problem was what it was.
I am thinking, because of how the question is stated, that the answer is the maxiumum amount of force that both balls can sucessfully exert on each other. It cannot be the greater force exerted by one or the because in that case the other ball wound't be able to exert anywhere near that amount of force and the question says ".. maxiumum gravitational force that each can exert on the other..." - stressing the word EACH.
So coudl someone explain to me what kind of answer this problem is looking for? Thanks.
The gravitational force between 2 objects is equal. Newton law of universal gravitation says so. Now think of what situation the 2 balls could be in that would maximize the force.
?? :( Still lost sorry
Due to gravity, I am exerting a force on you right now. You are exerting the exact same force on me. Understand that?
Newtons law of Universal gravitation:
[tex]F=\frac{Gm_1 m_2}{r^2}[/tex]
So, the force exerted on one body by the other is dependent on the masses (which we can't change) and the distance between the two bodies.
What situation would make this force a maximum?
Obviously if they were really really really far away from each other, the force would be small.
How close can they get? What would the force be when they were that close?
[SIZE=-20]10characters
the strength of the gravitational force is related to the inverse square of the distance between the center of mass of the two objects. try thinking about this problem in two dimensions. imagine you cut a slice out of the exact center of each sphere (with radius exactly the same as the sphere) and then put them as close as possible to each other. what's the distance between the center of each circle?
now you know the distance the force is acting over, which should make the problem relatively simple.
the max is when they are right next to each other touching, the force of gravity acts on the center of mass of the object (ie a point mass in the center of each ball) at least that's my understanding, so u min the distance makes a max in the force that EACH exterts on each other, if ur having trouble understanding this, try understanding that if they were far away from each other an no other masses in the universe exsisted, they would attract each other, and ur problem i pressume is that yes the smaller (lower massed) ball would have a greater acceleration toward the bigger (more massive) ball, however they have the same FORCE acting on each ball and they are attracked to the center of mass of the system of the two balls, hope that helps...
9K
