A question about string tension
  • Thread starter Thread starter Carnivean
    String Tension
The discussion centers on calculating the tension required for a violin A string with a fundamental frequency of 440Hz, a vibrating length of 31.2cm, and a mass of 0.355g. The key formula used is the relationship between tension, mass per unit length, and wave velocity, expressed as V = √(Tension/(mass/length)). The user correctly identifies the need to convert mass from grams to kilograms for accurate tension calculation in Newtons. The final tension can be derived by rearranging the formula to solve for Tension.
  • Understanding of wave mechanics and string vibrations
  • Knowledge of unit conversions, specifically grams to kilograms
  • Familiarity with the formula for wave velocity in strings
  • Basic algebra for rearranging equations
  • Learn about the relationship between frequency, wavelength, and wave speed in strings
  • Study the principles of tension in vibrating strings and their physical implications
  • Explore unit conversion techniques, particularly in physics contexts
  • Investigate the effects of string tension on sound quality in string instruments
Musicians, physics students, and string instrument makers who are interested in the physics of sound production and string tension calculations.
Carnivean
The A string on a violin has a fundamental frequency of 440Hz.
The length of the vibrating portion is 31.2cm and has a mass of
0.355g. Under what tension must the string be placed? (Find the
answer in the usual metric unit of tension, the Newton, but do not enter
units)
square root of Tension/(mass/length) = velocity of string.
Velocity = frequency X wavelength
Soo... V = square root OF Tension/ (.355g/.321 m) (or do I need to convert grams to kilograms?)
So to find velocity i was thinking V = frequency X wavelength. So... (440Hz X .642) which is 282.48..
So velocity = 282.48? then that would mean that 282.48 = squareroot of Tension/ (.355g/.321 m) ?
Am I on the right track?
Always keep an eye on units. Since you need tension in Newtons, you mass always needs to be in kilograms (1 Newton is equal to 1 kg.m.s-2)
  • · Replies 29 ·
  • · Replies 26 ·
  • · Replies 23 ·
