| New Reply |
Direction of damping force on a surface |
Share Thread |
| Aug5-11, 06:31 AM | #1 |
Hi
Suppose a particle is bouncing on a surface with a viscous damping coefficient... Question 1: The frictional force = -c(viscous damping coefficient)*v(velocity of the particle) But what is the direction of this force? Perpendicular [down] to surface? So if the surface is tilted at an angle what would the frictional force be? Question 2: Is it possible to express frictional force [due to damping] using force due to gravity (on the point of impact) and not velocity? Thanks |
| Aug5-11, 06:55 AM | #2 |
But if you just drop a ball on tilted surface, or throw it at any other angle, you will have combined effect of damping friction (depending on velocity component perpendicular to the surface), friction in motion parallel to the surface, and energy transfer to rotation of your ball. [quote]Is it possible to express frictional force [due to damping] using force due to gravity (on the point of impact) and not velocity?[quote] Nope. Just take extreme case: if you lay your ball on a table (velocity is 0) there is no dumping friction, but gravity is always the same. |
| Aug5-11, 08:40 AM | #3 |
[QUOTE=xts;3437384]Yes.
if your ball hits the surface perpendicularly - the force is as you wrote. But if you just drop a ball on tilted surface, or throw it at any other angle, you will have combined effect of damping friction (depending on velocity component perpendicular to the surface), friction in motion parallel to the surface, and energy transfer to rotation of your ball. [quote]Is it possible to express frictional force [due to damping] using force due to gravity (on the point of impact) and not velocity? About the angled surface... Ignoring the surface friction, would the damping force decrease by an angle of cos(theta) or something like that? |
| Aug5-11, 08:59 AM | #4 |
| Aug5-11, 09:54 AM | #5 |
Do you know any other means of measuring the damping force [by the surface on the particle] other than using velocity? |
| Aug5-11, 10:22 AM | #6 |
You may use tensometer, or some kind of scale: eg a light plate glued on piezoelement, but velocity seems to be definitely the simplest and most feasible for no-budget home experiment
| Aug5-11, 10:34 AM | #7 |
One last question: The force exerted by the plate at point of collision.... Is is it ok to say this force is damped by a factor (1–(c))? |
| Aug5-11, 10:37 AM | #8 |
It definitely is wrong, I wonder why do you think so? |
| Aug5-11, 11:06 AM | #9 |
| New Reply |
| Tags |
| damping |
Similar discussions for: Direction of damping force on a surface
| Force , Resultant Force, Magnitude & Direction | Introductory Physics Homework | 1 | ||
| resonance - working out damping constant and damping factor | Advanced Physics Homework | 3 | ||
| [Problem]: Magnitude/direction of magnetic force, electric force and the net force. | Introductory Physics Homework | 5 | ||
| [SOLVED] Pendulum Damping Force | Introductory Physics Homework | 3 | ||
| Constant damping force on springsystem | Introductory Physics Homework | 1 | ||
