Finding atomic weight from vapor density of metal chloride
The discussion revolves around determining the atomic weight of a metal based on the vapor density of its chloride and the composition of its oxide. Participants explore the relationships between vapor density, molar mass, and the percentage composition of the metal in the oxide, engaging in a problem-solving context.
  • Homework-related
  • One participant presents a problem involving the vapor density of a metal chloride and its oxide, noting that the oxide contains 53% metal by mass.
  • Another participant points out that vapor density is a physical quantity and questions the unitless representation provided.
  • Some participants clarify that vapor density is a ratio of the mass of a gas to the mass of an equal volume of hydrogen, leading to the formula for molar mass.
  • A participant proposes a mathematical approach to relate the valency of the metal and its atomic mass, suggesting a system of equations based on the given percentages and vapor density.
  • There is a challenge regarding the interpretation of the percentage of metal in the oxide, with one participant asserting it must be by mass.
  • Another participant expresses frustration with the pace of the discussion and seeks clearer guidance on forming equations related to the problem.
  • One participant suggests that if the vapor density is defined with respect to hydrogen, the value used in calculations should be adjusted accordingly.
Participants do not reach a consensus on the interpretation of the problem or the best approach to solve it. There are competing views on the definitions and calculations involved, and some participants express confusion about the mathematical relationships.
Participants discuss various interpretations of vapor density and its implications for solving the problem, with some uncertainty regarding the definitions and how they apply to the specific case of the metal chloride and its oxide.
Quantum Mind
Vapor density of a metal chloride is 66. Its oxide contains 53% metal. The atomic weight of the metal is ?
vapor density = 0.5 * molar mass
Using the above formula, I found the molar mass of the metal chloride as 132. I am stuck here, as the problem talks about the oxide containing 53% metal.
In 100 g of Metal oxide, 47% is oxygen, i.e. roughly the weight of three oxygen atoms which is 48. The Formula is therefore M2O3 ? Does this mean that this metal is hexa valent? This doesn't seem right, because the mol wt of chlorine is 35.5 and six chlorine atoms would weigh 213 g whereas the sample is only 132 g.
The choices for answer are 21, 54, 27.06 and 2.7.
Logically I think the answer should be 54, as this would correspond to cobalt while the rest are not metals.
Can anybody please explain how the answer is to be arrived at?
density is a physical quantity with units. you had presented a unitless quantity for it.
Vapor density is a ratio, being a proportion of mass. Therefore no unit.
Now, how do I go about solving the problem?
Proportion between what masses?
Vapour density (or vapor density) is the density of a vapour in relation to that of hydrogen. It may be defined as mass of a certain volume of a substance divided by mass of same volume of hydrogen.
vapour density = mass of n molecules of gas / mass of n molecules of hydrogen
(By definition, the molar mass of a gas is the ratio of the mass of one molecule of gas to that of an hydrogen atom under similar conditions.)
Therefore:
vapour density = molar mass of gas / molar mass of H2
vapour density = molar mass of gas / 2
vapour density = ½ × molar mass
(and thus: molar mass = 2 × vapour density)
Source: http://en.wikipedia.org/wiki/Vapour_density"
Is the content of metal in the oxide given by mass or by number?
I have reproduced the question exactly. It has to be 53% by mass since molar mass is involved.
Sorry if I sound rude, but the discussion doesn't seem to be going anywhere.
Suppose the valency of the metal is v and its atomic mass is x. Then the ratio of the masses of the metal and oxygen in the oxide is:
[tex] \frac{2 \, x}{16 \times v} = \frac{53}{47} \Rightarrow 94 \, x = 848 \, v \Rightarrow 47 \, x = 424 \, v[/tex]
Next, the molar mass of the chloride is:
[tex] 1 \times x + v \times 35 = 66 \Rightarrow x + 35 \, v = 66[/tex]
where I had used the definition of vapour density.
Now, you have 2 linear equations in 2 unknowns (x and v). Solve them
or, if the vapour density is defined with respect to H2, then you should substitute the 66 in the second equation with a 132.
Thanks for the reply, but I still don't understand. The ratio of the masses of the metal and the oxide is 53:47 as per the question. How do I relate it to valency and atomic mass and form an equation with v and x?
Can you make it a bit clearer?
No, this is enough hints. If you cannot solve it, that's your problem.
17K
64K
