Momentum and Vectors: Solving a Car Collision Problem
  • Thread starter Thread starter HeRo
    Momentum Vectors
This discussion focuses on calculating impulse and average force in a car collision scenario involving a 1300 kg car. The car initially travels north at 5.0 m/s, makes a 90° right-hand turn, and comes to a stop after colliding with a tree. The impulse during the turn is calculated as 6500 kg·m/s in the positive x direction, while the impulse during the collision is 0 kg·m/s. The average force during the turn is determined to be 1477.3 N in the positive x direction, with the average force during the collision being calculated based on the change in momentum.
  • Understanding of impulse and momentum concepts
  • Knowledge of unit-vector notation
  • Ability to calculate average force using impulse
  • Familiarity with basic physics equations
  • Study the relationship between impulse and momentum in physics
  • Learn how to apply unit-vector notation in physics problems
  • Explore the concept of average force and its calculations
  • Investigate real-world applications of momentum in collision scenarios
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone interested in understanding the dynamics of car collisions and impulse calculations.
HeRo
Ok, so I've started on momentum recently but now I've hit a problem. I'm not sure how to handle the following situation:
A 1300 kg car moving at 5.0 m/s is initially traveling north in the positive y direction. After completing a 90° right-hand turn to the positive x direction in 4.4 s, the inattentive operator drives into a tree, which stops the car in 350 ms.
(a) In unit-vector notation, what is the impulse on the car during the turn?
(b) In unit-vector notation, what is the impulse on the car during the collision?
(c) What is the average force that acts on the car during the turn?
(d) What is the average force that acts on the car during the collision?
(e) What is the angle between the average force in (c) and the positive x direction?
Help is appreciated :eek:
Any part in particular?
Do you know what impulse is?
How would you go about calculating average force? Or, for that matter, average anything?
--J
Hi there, it sounds like you're working on some interesting problems with momentum and vectors. Let's see if we can break down this car collision problem and solve it step by step.
First, let's identify the given information. We know the mass of the car (1300 kg), its initial velocity (5.0 m/s), and the time it takes to complete the turn (4.4 s). We also know that the car comes to a stop in 350 ms (or 0.350 s) after hitting the tree.
Now, let's think about the concept of impulse. Impulse is defined as the change in momentum, and it is represented by the symbol J. In this problem, we have two separate impulses - one during the turn and one during the collision with the tree.
(a) In unit-vector notation, the impulse during the turn can be represented as J = mΔv. Since we are given the mass (1300 kg) and the change in velocity (from 5.0 m/s in the positive y direction to 5.0 m/s in the positive x direction), we can plug these values into the equation to get J = (1300 kg)(5.0 m/s)i = 6500 kg·m/s i. This means that the impulse during the turn is 6500 kg·m/s in the positive x direction.
(b) The impulse during the collision can be found using the same equation, J = mΔv, but this time we will use the final velocity of 0 m/s (since the car comes to a stop) and the time it takes for the car to stop (0.350 s). This gives us J = (1300 kg)(0 m/s)i = 0 kg·m/s i. This means that the impulse during the collision is 0 kg·m/s in the positive x direction.
(c) Average force is defined as the change in momentum divided by the time interval over which the change occurs. In this case, the change in momentum is the same as the impulse calculated in part (a), 6500 kg·m/s i. The time interval is given as 4.4 s, so the average force during the turn is (6500 kg·m/s i)/(4.4 s) = 1477.3 N i.
(d) Similarly, the average force during the collision can be found using the impulse
  • · Replies 32 ·
